Windows Update 1709 stops with error 0x80070522 at 71%, MCT as alternative does not start, need help
Diskutiere Windows Update 1709 stops with error 0x80070522 at 71%, MCT as alternative does not start, need help im Windows 10 Forum im Bereich Microsoft Community; Hello Community, HW: HP spectre X360 G1 with Windows 10 1703 build 15063.850. With usual Windows update it doesn't find any new updates, tells...
Hello Community,
With usual Windows update it doesn't find any new updates, tells that system is actual.
So i downloaded WindowsUpdateAssistent from MS site, starts, tells the prereq's are sufficient, and downloads, then installs. But at 71% ist fails with error 0x80070522. Found documentation to this code telling something with administration access is missing, but what more can i do than log in as adiministrator and, of course all was executed "as administrator" from contect menu.
I finally downloaded Media Creation tool, but this cannot start, tells there is a problem, should try reboot, this doesn't help, same error.
I am working with local administrator account (same issues with domain account as member of administrators group).
UAC is at lowest level. Issues do appear with deactivated MS Firewall and disabled Avira AV.
C: Partition has ~78 Gb free ssd space.
I executed "TroubleShooting WindowsUpdate" from Control Panel, repairs it and resolved everything but not "some security settings not found or changed", that is the only issue marked with a red cross, which is not resolved. All other found topics are resolved.
Did clean up C:\ with cleanmgr.exe, did mark all available values, but this is either not helping.
Did change folder names of c:\windows.old, C:\$windows.~WS, C:\$windows.~BT and moved them to other directory (i.e. c:\temp).
It is not possible to remove these folders competely, bcoz the ownership or access of TrustedInstaller (C:\$windows.~BT) or SYSTEM (c:\windows.old) cannot be given to administrator (even not working with cacls, icacls and all tipps given in forums, always "access denied".
Here are the latest WindowsUpdate.log entries from the bottom (~ 30 lines):
2018.01.12 13:36:12.8939031 10196 4800 IdleTimer [0]27D4.12C0::01/12/2018-13:36:12.893 [agent]WU operation (CSearchCall::Init ID 2, operation # 6) stopped; does not use network; is not at background priority
2018.01.12 13:36:12.8950381 11564 11312 ComApi [0]2D2C.2C30::01/12/2018-13:36:12.895 [comapi]*RESUMED* Search ClientId = <
>: taskhostw.exe, ServiceId = 7971F918-A847-4430-9279-4A52D1EFE18D (cV = Xe0jWaDGy0C4rCnp.1.0.0)
2018.01.12 13:36:12.8953535 11564 11312 ComApi [0]2D2C.2C30::01/12/2018-13:36:12.895 [comapi]* END * Search ClientId = <
>: taskhostw.exe, Updates found = 0, ServiceId = 7971F918-A847-4430-9279-4A52D1EFE18D (cV = Xe0jWaDGy0C4rCnp.1.0.0)
2018.01.12 13:36:12.8954798 11564 1400 ComApi [0]2D2C.0578::01/12/2018-13:36:12.895 [comapi]* END * All federated searches have completed. Jobs = 2, Succeeded = 2, ClientId = <
>: taskhostw.exe (cV = Xe0jWaDGy0C4rCnp.1.0)
2018.01.12 13:36:12.8966984 11564 1996 ComApi [0]2D2C.07CC::01/12/2018-13:36:12.896 [comapi]ISusInternal:: DisconnectCall failed, hr=8024000C
2018.01.12 13:36:12.8983955 11564 1996 ComApi [0]2D2C.07CC::01/12/2018-13:36:12.898 [comapi]ISusInternal:: DisconnectCall failed, hr=8024000C
2018.01.12 13:36:12.9000823 11564 1996 ComApi [0]2D2C.07CC::01/12/2018-13:36:12.900 [comapi]ISusInternal:: DisconnectCall failed, hr=8024000C
2018.01.12 13:46:12.9017813 10196 5344 Agent [0]27D4.14E0::01/12/2018-13:46:12.901 [agent]Earliest future timer found:
2018.01.12 13:46:12.9017924 10196 5344 Agent [0]27D4.14E0::01/12/2018-13:46:12.901 [agent] Timer: 29A863E7-8609-4D1E-B7CD-5668F857F1DB, Expires 2018-01-13 11:25:16, not idle-only, not network-only
2018.01.12 13:46:13.9030742 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:13.903 [agent]CSusClientGlobal::DoServicePreShutdown
2018.01.12 13:46:13.9031942 10196 11992 IdleTimer [0]27D4.2ED8::01/12/2018-13:46:13.903 [agent]Idle timer disabled in preparation for service shutdown
2018.01.12 13:46:13.9032238 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:13.903 [agent]WUTaskManager uninit
2018.01.12 13:46:13.9032250 10196 11992 Agent [0]27D4.2ED8::01/12/2018-13:46:13.903 [agent]Earliest future timer found:
2018.01.12 13:46:13.9032317 10196 11992 Agent [0]27D4.2ED8::01/12/2018-13:46:13.903 [agent] Timer: 29A863E7-8609-4D1E-B7CD-5668F857F1DB, Expires 2018-01-13 11:25:16, not idle-only, not network-only
2018.01.12 13:46:13.9045944 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:13.904 [susenginelib]CreateSessionStateChangeTrigger, TYPE:2, Enable:No
2018.01.12 13:46:13.9045991 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:13.904 [susenginelib]CreateSessionStateChangeTrigger, TYPE:4, Enable:No
2018.01.12 13:46:13.9287982 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:13.928 [agent]Agent uninit
2018.01.12 13:46:13.9288349 10196 11992 Handler [0]27D4.2ED8::01/12/2018-13:46:13.928 [lib]CUHCbsHandler::CancelDownloadRequest called
2018.01.12 13:46:13.9297531 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:13.929 [agent]Reporter uninit
2018.01.12 13:46:13.9298269 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:13.929 [agent]network cost manager uninit
2018.01.12 13:46:13.9298490 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:13.929 [agent]Eventer uninit
2018.01.12 13:46:14.9313049 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:14.931 [agent]ServiceManager uninit
2018.01.12 13:46:14.9313523 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:14.931 [agent]PersistentTimeoutScheduler uninit
2018.01.12 13:46:14.9313590 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:14.931 [agent]datastore uninit
2018.01.12 13:46:14.9441365 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:14.944 [agent]setting cache uninit
2018.01.12 13:46:14.9441373 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:14.944 [agent]security checker uninit
2018.01.12 13:46:14.9441404 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:14.944 [agent]Test Hook uninit
2018.01.12 13:46:14.9441408 10196 11992 Misc [0]27D4.2ED8::01/12/2018-13:46:14.944 [agent]IdleTimer uninit
2018.01.12 13:46:14.9449394 10196 11992 Shared [0]27D4.2ED8::01/12/2018-13:46:14.944 [agent]* END * Service exit Exit code = 0x240001 --
So i am now at the point where all research in forums where these sort of issues were discussed beginning about 2015, are not helping here or i cannot find anything to resolve it.
Does anyone have "new" ideas or tipps what can help to get "fall creator update" installed?
I really need experts support here:
a) what can i do to get MCT to start?
b) or what can i do to get WindowsUpdateAssistent install update 1709 to 100%
c) or is there anyone out there knowing what exitcode 0x240001 in the log means?
btw, event log does not show anything either.
BR Wolf
Windows Update 1709 stops with error 0x80070522 at 71%, MCT as alternative does not start, need help - Ähnliche Themen
Headset not working fine with Windows: Hi everyone I have in general a problem with my Headsets that are connected to my Headset. I can connect the headset to windows an i can hear...
A critical system process, C:\Windows\system32\lsass.exe, failed with status code 1073741819: Hi, since 05.07.2020 my Laptop HP Pavilion always reboots with the following message: Sometimes the user cant login and there is only the...
BoD (DPC_WATCHDOG_VIOLATION / VIDEO_TDR_FAILURE) due to graphics driver or faulty hardware?: Since quite some time I regularly get BoDs with a DPC_WATCHDOG_VIOLATION (133) and after some driver changes VIDEO_TDR_FAILURE (116)...
WIN 10 Microsoft Store EXTREMELY slow download.: I bought Forza Horizon 3 and it just won't download (like any other app). Its always "In Queue" or it says "starting download" but after a while...
windows 10 update loop error 0x800f0922: Hi Long time ago I faced an update loop on a win 7 installation. All previous updates were successful, but from this point in time updates...
