- Dabei seit
- 20.09.2016
- Beiträge
- 94.182
mein Upgrade auf (1709) schlägt immer wieder fehl. Egal ob per DVD(ISO) oder per Windows Update-Funktion
Laut DISM ist alles in Ordnung
Ich komme nicht mehr weiter. Es muss doch neben einer Kompletten Neuinstallation auch andere Möglichkeiten geben das zu lösen
Im CBS.log steht folgendes:
2017-12-06 17:35:20, Info CBS TI: --- Initializing Trusted Installer ---
2017-12-06 17:35:20, Info CBS TI: Last boot time: 2017-12-06 17:19:54.497
2017-12-06 17:35:20, Info CBS Starting TrustedInstaller initialization.
2017-12-06 17:35:20, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:4
2017-12-06 17:35:20, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:5
2017-12-06 17:35:20, Info CBS Lock: New lock added: WinlogonNotifyLock, level: 8, total lock:6
2017-12-06 17:35:20, Info CBS Ending TrustedInstaller initialization.
2017-12-06 17:35:20, Info CBS Starting the TrustedInstaller main loop.
2017-12-06 17:35:20, Info CBS TrustedInstaller service starts successfully.
2017-12-06 17:35:20, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2017-12-06 17:35:20, Info CBS Startup processing thread terminated normally
2017-12-06 17:35:20, Info CBS TI: Startup Processing completes, release startup processing lock.
2017-12-06 17:35:20, Info CBS WU creates the package, AppID:<
>: taskhostw.exe, UpdateID:{711AEBA3-A5B3-4384-9DE6-9956EBFDE0D4}, revision: 200
2017-12-06 17:35:20, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4033631~31bf3856ad364e35~amd64~~10.0.1.0, ApplicableState: 112, CurrentState:0
2017-12-06 17:35:21, Info CBS WU creates the package, AppID:<
>: taskhostw.exe, UpdateID:{6889ECF7-F075-4F4F-8DB1-33E4835A79F6}, revision: 200
2017-12-06 17:35:21, Info CBS Read out cached applicability from TiLight for package: Package_for_RollupFix~31bf3856ad364e35~amd64~~15063.726.1.7, ApplicableState: 112, CurrentState:112
2017-12-06 17:35:23, Info CBS WU creates the package, AppID:<
>: taskhostw.exe, UpdateID:{27257186-E16F-4269-8909-FAC342C7563C}, revision: 201
2017-12-06 17:35:23, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4035543~31bf3856ad364e35~amd64~~10.0.1.0, ApplicableState: 80, CurrentState:0
2017-12-06 17:35:27, Info CBS WU creates the package, AppID:<
>: taskhostw.exe, UpdateID:{5E718700-ECD2-4060-8FEB-5F7B11092131}, revision: 201
2017-12-06 17:35:27, Info CBS Read out cached applicability from TiLight for package: Package_for_KB4049011~31bf3856ad364e35~amd64~~10.0.1.2, ApplicableState: 112, CurrentState:112
2017-12-06 17:37:27, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2017-12-06 17:37:27, Info CBS Ending the TrustedInstaller main loop.
2017-12-06 17:37:27, Info CBS Starting TrustedInstaller finalization.
2017-12-06 17:37:27, Info CBS Ending TrustedInstaller finalization.
2017-12-06 20:41:27, Info CBS TI: --- Initializing Trusted Installer ---
2017-12-06 20:41:27, Info CBS TI: Last boot time: 2017-12-06 20:34:04.497
2017-12-06 20:41:27, Info CBS Starting TrustedInstaller initialization.
2017-12-06 20:41:27, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:4
2017-12-06 20:41:27, Info CBS Lock: New lock added: CCbsPublicSessionClassFactory, level: 30, total lock:5
2017-12-06 20:41:27, Info CBS Lock: New lock added: WinlogonNotifyLock, level: 8, total lock:6
2017-12-06 20:41:27, Info CBS Ending TrustedInstaller initialization.
2017-12-06 20:41:27, Info CBS Starting the TrustedInstaller main loop.
2017-12-06 20:41:27, Info CBS TrustedInstaller service starts successfully.
2017-12-06 20:41:27, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2017-12-06 20:41:27, Info CBS Startup processing thread terminated normally
2017-12-06 20:41:27, Info CBS TI: Startup Processing completes, release startup processing lock.
2017-12-06 20:41:27, Info CBS Starting TiWorker initialization.
2017-12-06 20:41:27, Info CBS Lock: New lock added: TiWorkerClassFactory, level: 30, total lock:2
2017-12-06 20:41:27, Info CBS Ending TiWorker initialization.
2017-12-06 20:41:27, Info CBS Starting the TiWorker main loop.
2017-12-06 20:41:27, Info CBS TiWorker starts successfully.
2017-12-06 20:41:27, Info CBS Lock: New lock added: CCbsWorker, level: 5, total lock:3
2017-12-06 20:41:27, Info CBS Universal Time is: 2017-12-06 19:41:27.412
2017-12-06 20:41:27, Info CBS Loaded Servicing Stack v10.0.15063.724 with Core: C:\Windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.15063.724_none_9e8a868b2d8a538d\cbscore.dll
2017-12-06 20:41:27, Info CSI [email protected]/12/6:19:41:27.415 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fff5f054219 @0x7fff5f44ce96 @0x7fff5f44c1a4 @0x7ff741542bc2 @0x7ff7415433a0 @0x7fff94a49083)
2017-12-06 20:41:27, Info CBS Lock: New lock added: CCbsSessionManager, level: 11, total lock:14
2017-12-06 20:41:27, Info CBS Lock: New lock added: CSIInventoryCriticalSection, level: 64, total lock:15
2017-12-06 20:41:27, Info CBS Lock: New lock added: FlightPackageCacheCriticalSection, level: 128, total lock:16
2017-12-06 20:41:27, Info CBS Lock: New lock added: CCbsWorkerQueue, level: 60, total lock:17
2017-12-06 20:41:27, Info CBS Lock: New lock added: CCbsWorkerQueue:m_WindowsUpdateExpressDownloadLock, level: 10, total lock:18
2017-12-06 20:41:27, Info CBS NonStart: Set pending store consistency check.
2017-12-06 20:41:27, Info CBS Session: 30633674_887890824 initialized by client WindowsUpdateAgent, external staging directory: (null), external registry directory: (null
2017-12-06 20:41:27, Info CBS Failed to internally open package. [HRESULT = 0x800f0805 - CBS_E_INVALID_PACKAGE]
2017-12-06 20:41:27, Info CBS Failed to OpenPackage using worker session [HRESULT = 0x800f0805]
2017-12-06 20:41:27, Info CBS Releasing offline store key
2017-12-06 20:41:27, Info CBS Session: 30633674_887910852 initialized by client WindowsUpdateAgent, external staging directory: (null), external registry directory: (null
