Win8 Bluescreen immer wieder
Diskutiere Win8 Bluescreen immer wieder im Win8 - Hardware Forum im Bereich Windows 8 Forum; Hallo! Mein Windows 8 stürzt immer wieder ab mit whocrashed habe ich es analysiert und folgende Fehlermeldung bekommen,: Klingt für mich nach...
Duketom
Hallo!
mit whocrashed habe ich es analysiert und folgende Fehlermeldung bekommen,: Klingt für mich nach einem Windowsproblem oder ? wie kann man dies beheben ?
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Wed 22.05.2013 13:54:11 GMT your computer crashed
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: Unknown (0xFFFFF802C022606C)
Bugcheck code: 0xD1 (0xFFFFF802C022606C, 0x2, 0x8, 0xFFFFF802C022606C)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error.
Google query: DRIVER_IRQL_NOT_LESS_OR_EQUAL
On Wed 22.05.2013 04:24:52 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\052213-17534-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x905C0)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF800C38955C0, 0xFFFFF88002DC59D8, 0xFFFFF88002DC5210)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Mon 20.05.2013 16:10:34 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\052013-17784-01.dmp
This was probably caused by the following module: netio.sys (NETIO+0x6943)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF8800193F943, 0xFFFFF8801EC1AC50, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
file path: C:\WINDOWS\system32\drivers\netio.sys
description: Network I/O Subsystem
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Mon 20.05.2013 15:41:26 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\052013-18954-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x5A440)
Bugcheck code: 0x139 (0x3, 0xFFFFF801DDC00A30, 0xFFFFF801DDC00988, 0x0)
Error: KERNEL_SECURITY_CHECK_FAILURE
Bug check description: The kernel has detected the corruption of a critical data structure.
On Wed 24.04.2013 16:25:53 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\042413-19328-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x5A240)
Bugcheck code: 0x50 (0xFFFFF8015BAB2067, 0x8, 0xFFFFF8015BAB2067, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
areiland
areiland
Stell uns bitte mal die Dumpfiles zur Verfügung! Der Pfad werden in jeweils der zweiten Zeile genannt - einpacken und uns einen Link zum Download nennen. Erst dann kann man wirklich was sagen.
Win8 Bluescreen immer wieder - Ähnliche Themen
  • Bluescreen unter Win8 64-Bit - File: BCD Error Code: 0xc0000034
    Bluescreen unter Win8 64-Bit - File: BCD Error Code: 0xc0000034: Hallöchen, Wie der Titel schon sagt, bekomme ich ständig einen bestimmten Bluescreen. Ich habe das Windows 8 Upgrade vor einigen Tagen gekauft...
  • PC stürzt unter Windows 8 unregelmäßig ab
    PC stürzt unter Windows 8 unregelmäßig ab: Hallo sehr geehrte Leser ich habe ein Problem mit meinem Rechner... In unregelmäßigen Abständen kriege ich einen Bluescreen und der Sound hängt...
  • Desktopsymbole lassen sich nicht mehr anordnen Win8
    Desktopsymbole lassen sich nicht mehr anordnen Win8: Hallo zusammen, bei meiner Win 8.1 Pro Version lassen sich die Desktop Symbole nicht mehr verschieben bzw. anordnen. Jemand eine Idee wie man...
  • GELÖST von Winn7...auf Win8 gehen :)
    GELÖST von Winn7...auf Win8 gehen :): Moin die Experten hier hatten mir ja beim Dell Neuling gut geholfen aber... als klar war das ich das Notebock mit Win7 betreiben wollte......bekam...
