Wie bau ich des bloss ein???
Diskutiere Wie bau ich des bloss ein??? im Internet Forum Forum im Bereich Software Forum; Hi Leute ich habe hier eine PHP Datei: <? /*    == Stats ==    Author: joshdw1    E-Mail: [email protected]    Website...
Pascal
Pascal
40
Internet, Links, beim nächsten Router Rechts, dana
Hi Leute
Code:
    == Stats ==
    Author: joshdw1
    E-Mail: [email][email protected][/email]
    Website: [URL=http://www.ibhacks.com]http://www.ibhacks.com[/URL]
    This hack is made for IBHacks ([url]www.ibhacks.com)[/url] and cannot be distributed on other pages except the author's personal webpage without explicit permission. If you like to re-distribute this hack, please send an e-mail describing your reasons to [email][email protected][/email]
    Description: Display various statistics about your forum
    Version: IBF.PHP BETA 1
    Installing: Rename this file to stats.php, then edit the setup info.  After that you simply need to
      include it wherever you want the stats to appear.  You should also edit the style
      to fit your site.
    // Setup Info
    $server = 'xxxx';
    $user   = 'xxx';
    $pass   = 'xxx';
    $db     = 'xxx';
    $stats_table = 'board_stats';
    $sess_table  = 'board_sessions';
    $link_id = mysql_pconnect($server, $user, $pass);
    mysql_select_db($db, $link_id);
    // Get Stats
    $statquery = "SELECT TOTAL_REPLIES, TOTAL_TOPICS, MOST_COUNT, MEM_COUNT FROM $stats_table";
    $query_id = mysql_query($statquery, $link_id);
    $statinfo = mysql_fetch_array($query_id, MYSQL_ASSOC);
    $total_posts = $statinfo[TOTAL_TOPICS] + $statinfo[TOTAL_REPLIES];
    $activetime = time() - 900;
    $activequery = "SELECT DISTINCT count(*) as online_users FROM $sess_table WHERE running_time > $activetime";
    $query_id = mysql_query($activequery, $link_id);
    $activeinfo = mysql_fetch_array($query_id, MYSQL_ASSOC);
    // Display Stats (modify this to fit your site)
    echo "
                <p><font size=\"1\" face=\"Verdana, Arial, Helvetica, sans-serif\" color=\"#666666\">[b]Statistics:[/b]
                  Active Users: [b]$activeinfo[online_users][/b]
                  Total Topics: [b]$statinfo[TOTAL_TOPICS][/b]
                  Total Replies: [b]$statinfo[TOTAL_REPLIES][/b]
                  Total Posts: [b]$total_posts[/b]
                  Total Members: [b]$statinfo[MEM_COUNT][/b]
                  Most Online: [b]$statinfo[MOST_COUNT][/b]
              </font></p>
Das sieht dann so aus:
http://www.winboard.ch/user_online.php
Wie bau ich das ein HTML Template auf meiner neuen Site, http://new.winland.ch ein?
thanks for help
Andy
Andy
Administrator
47
Wilder Süden
Also, das Teil wird in die Datei mit folgendem Befehl eingebaut:
Code:
<?php
include ("root/test/stats.php");
In einer HTML Datei hat das ganze aber keine Funktion und wird als normaler Kommentar betrachtet (also nicht abgearbeitet).
Du hast nun 2 Möglichkeiten.
1:
Die HTML Datei in eine *.PHP Datei umzubenennen.
Sobald die Datei die Endung PHP hat, funktioniert das ganze. Die Gefahr ist natürlich, dass dein Content-System dann nicht mehr funktioniert, weil die HTML Datei nicht mehr existiert. Musst du halt testen.
2.
Man kann in der .htaccess Datei angeben, dass alle HTML-Dateien als PHP Files geparst werden.
D.h. die HTML Dateien werden wie PHP Dateien behandelt.
Dazu in der .htaccess Datei folgende Zeile einbauen:
Code:
"AddType application/x-httpd-php .html"
Bei manchen Hostern ist diese Funktion allerdings gesperrt. Dann halt mit diesem Eintrag. Der geht genauso:
Code:
RewriteEngine On
RewriteRule ^(.+)\.htm /$1.php [L]
N
netdesign4u.de
38
Jetzt hätte ich mal mein Wissen als Mod umsetzen können, aber da ist mir Andy wohl zuvor gekommen ;D
Ich finde es irgendwie ungewöhnlich, eine Windows-Seite eine Layout mit Grün-Tönen zu verpassen. Ich würde da irgendwie eine ähnliche Farbkombination wie in diesem Forum bevorzugen.
Andy
Andy
Administrator
47
Wilder Süden
Außerdem wird wie ich meine rechts und links zu vioel Platz verschwendet.
OK, so ist die Seite auch bei 800x600 gut darstellbar.
Aber wenn du dir die Umfrage auf meiner Seite anschaust sind das gerade mal 7% der User
N
netdesign4u.de
38
Auf JAVA-mobil.de hatten seit Ende Januar 15% der Besucher 800x600 Pixel. Die darf man nicht einfach so ignorieren. Außerdem finde ich es so, wie es nach rechts rausgeschoben wird nich unbedingt schöner, aber die Grafik oben wirst du dann wohl noch verbreitern. Ich mache es eigentlich immer so, dass ich dann links und rechts etwas Platz verschenke und die Sites für 800x600 Pixel optimiere.
Ich würde insgesamt entweder den Namen stärker hervorheben oder ein bestimmtes Windows-Erkennungsmerkmal einfügen, damit man die Site schneller als Windows-Seite erkennt.
Auf der Startseite würde ich auf jeden Fall zu den Kurzbeschreibungen der News in der mittleren Spalte die eine oder andere Grafik hinzufügen, um beim ersten Eindruck für eine gewisse Auflockerung zu sorgen. Außerdem könnte man diese Kurzbeschreibungn optisch besser voneinander abgrenzen, z.B. durch eine dünne horizontale Linie oder durch zwei verschiedene Hintergrundfarben, die sich abwechseln (z.B: weiß und sehr hell grün-blau).
Der Platz für die Werbung ganz unten ist nicht optimal. Wenn du die Banner oben neben das Logo setzen würdest, wie hier im Forum, könntest du deutlich höhere Klickraten erzielen.
Wie bau ich des bloss ein??? - Ähnliche Themen
Absender bekommt Mail, dass unzustellbar und meine Adresse nicht existiert: Hallöchen, ich hatte das Problem schon vor einigen Jahren, dann war es weg und nun ist es plötzlich wieder da. Wenn mir jemand eine eMail...
Global dark theme is an awful dictation!: Hello fellow Windows 10 user, as I turned on my laptop this morning I noticed that after the update I installed yesterday some changes have...
Surface Laptop 3 | Audio Latenz Probleme | Wdf01000.sys: Ich habe seit letzter Woche einen neuen Surface Laptop 3 und nutze die DJ-Software Native Instruments Traktor 3 zusammen mit dem Hardware DJ Mixer...
Zugriff auf Postfach?: Ab diesem dieser Thread. Ich habe mir selber eine email geschickt und der hacker hat mir zurück geantwortet: I do know ma****05 is your pass...
Permanent auftretenden Mikroruckler -betrifft alle Anwendungen- Windows10/Spieleanwendungen: Hallo Liebe Community, seit einiger Zeit beschäftigen mich Mikroruckler und Lags im meinem System. Erst vielen mir die Lags beim zocken auf...
