2021-01-12 21:02:02, Info CBS TI: --- Initializing Trusted Installer ---
2021-01-12 21:02:02, Info CBS TI: Last boot time: 2021-01-12 19:08:45.490
2021-01-12 21:02:02, Info CBS TI: Anticipating that shutdown processing will be required.
2021-01-12 21:02:02, Info CBS Starting TrustedInstaller initialization.
2021-01-12 21:02:02, Info CBS Ending TrustedInstaller initialization.
2021-01-12 21:02:02, Info CBS Starting the TrustedInstaller main loop.
2021-01-12 21:02:02, Info CBS TrustedInstaller service starts successfully.
2021-01-12 21:02:02, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2021-01-12 21:02:02, Info CBS Startup processing thread terminated normally
2021-01-12 21:02:03, Info CBS Starting TiWorker initialization.
2021-01-12 21:02:03, Info CBS Ending TiWorker initialization.
2021-01-12 21:02:03, Info CBS Starting the TiWorker main loop.
2021-01-12 21:02:03, Info CBS TiWorker starts successfully.
2021-01-12 21:02:03, Info CBS Universal Time is: 2021-01-12 20:02:03.988
2021-01-12 21:02:03, Info CBS Loaded Servicing Stack v6.3.9600.19750 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.3.9600.19750_none_fa39f32f9b2d0928\cbscore.dll
2021-01-12 21:02:03, Info CSI
[email protected]/1/12:20:02:03.988 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7ff80b957f79 @0x7ff820bb3fe4 @0x7ff820bb35eb @0x7ff64d68d69a @0x7ff64d68df4f @0x7ff832e92053)
2021-01-12 21:02:04, Info CBS SQM: Initializing online with Windows opt-in: False
2021-01-12 21:02:04, Info CBS SQM: Cleaning up report files older than 10 days.
2021-01-12 21:02:04, Info CBS SQM: Requesting upload of all unsent reports.
2021-01-12 21:02:04, Info CBS SQM: Failed to start upload with file pattern: C:\WINDOWS\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:02:04, Info CBS SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:02:04, Info CBS SQM: Queued 0 file(s) for upload with pattern: C:\WINDOWS\servicing\sqm\*_all.sqm, flags: 0x6
2021-01-12 21:02:04, Info CBS SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:02:04, Info CBS NonStart: Set pending store consistency check.
2021-01-12 21:02:04, Info CBS Session: 30861597_3422705670 initialized by client WindowsUpdateAgent.
2021-01-12 21:04:04, Info CBS Trusted Installer successfully registered to be restarted for pre-shutdown
2021-01-12 21:04:04, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2021-01-12 21:04:04, Info CBS TiWorker signaled for shutdown, going to exit.
2021-01-12 21:04:04, Info CBS Ending the TiWorker main loop.
2021-01-12 21:04:04, Info CBS Ending the TrustedInstaller main loop.
2021-01-12 21:04:04, Info CBS Starting TiWorker finalization.
2021-01-12 21:04:04, Info CBS Starting TrustedInstaller finalization.
2021-01-12 21:04:04, Info CBS Ending TrustedInstaller finalization.
2021-01-12 21:04:04, Info CBS Ending TiWorker finalization.
2021-01-12 21:20:06, Info CBS TI: --- Initializing Trusted Installer ---
2021-01-12 21:20:06, Info CBS TI: Last boot time: 2021-01-12 19:08:45.490
2021-01-12 21:20:06, Info CBS TI: Anticipating that shutdown processing will be required.
2021-01-12 21:20:06, Info CBS Starting TrustedInstaller initialization.
2021-01-12 21:20:06, Info CBS Ending TrustedInstaller initialization.
2021-01-12 21:20:06, Info CBS Starting the TrustedInstaller main loop.
2021-01-12 21:20:06, Info CBS TrustedInstaller service starts successfully.
2021-01-12 21:20:06, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2021-01-12 21:20:06, Info CBS Startup processing thread terminated normally
2021-01-12 21:20:06, Info CBS Starting TiWorker initialization.
2021-01-12 21:20:06, Info CBS Ending TiWorker initialization.
2021-01-12 21:20:06, Info CBS Starting the TiWorker main loop.
2021-01-12 21:20:06, Info CBS TiWorker starts successfully.
2021-01-12 21:20:06, Info CBS Universal Time is: 2021-01-12 20:20:06.403
2021-01-12 21:20:06, Info CBS Loaded Servicing Stack v6.3.9600.19750 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.3.9600.19750_none_fa39f32f9b2d0928\cbscore.dll
2021-01-12 21:20:06, Info CSI
[email protected]/1/12:20:20:06.403 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7ff80b957f79 @0x7ff813d13fe4 @0x7ff813d135eb @0x7ff64d68d69a @0x7ff64d68df4f @0x7ff832e92053)
2021-01-12 21:20:06, Info CBS SQM: Initializing online with Windows opt-in: False
2021-01-12 21:20:06, Info CBS SQM: Cleaning up report files older than 10 days.
2021-01-12 21:20:06, Info CBS SQM: Requesting upload of all unsent reports.
2021-01-12 21:20:06, Info CBS SQM: Failed to start upload with file pattern: C:\WINDOWS\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:20:06, Info CBS SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:20:06, Info CBS SQM: Queued 0 file(s) for upload with pattern: C:\WINDOWS\servicing\sqm\*_all.sqm, flags: 0x6
2021-01-12 21:20:06, Info CBS SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:20:06, Info CBS NonStart: Set pending store consistency check.
2021-01-12 21:20:06, Info CBS Session: 30861600_1361798587 initialized by client WindowsUpdateAgent.
2021-01-12 21:22:06, Info CBS Trusted Installer successfully registered to be restarted for pre-shutdown
2021-01-12 21:22:06, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2021-01-12 21:22:06, Info CBS TiWorker signaled for shutdown, going to exit.
2021-01-12 21:22:06, Info CBS Ending the TrustedInstaller main loop.
2021-01-12 21:22:06, Info CBS Ending the TiWorker main loop.
2021-01-12 21:22:06, Info CBS Starting TrustedInstaller finalization.
2021-01-12 21:22:06, Info CBS Starting TiWorker finalization.
2021-01-12 21:22:06, Info CBS Ending TrustedInstaller finalization.
2021-01-12 21:22:06, Info CBS Ending TiWorker finalization.
2021-01-12 21:22:58, Info CBS TI: --- Initializing Trusted Installer ---
2021-01-12 21:22:58, Info CBS TI: Last boot time: 2021-01-12 19:08:45.490
2021-01-12 21:22:58, Info CBS TI: Anticipating that shutdown processing will be required.
2021-01-12 21:22:58, Info CBS Starting TrustedInstaller initialization.
2021-01-12 21:22:58, Info CBS Ending TrustedInstaller initialization.
2021-01-12 21:22:58, Info CBS Starting the TrustedInstaller main loop.
2021-01-12 21:22:58, Info CBS TrustedInstaller service starts successfully.
2021-01-12 21:22:58, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2021-01-12 21:22:58, Info CBS Startup processing thread terminated normally
2021-01-12 21:22:58, Info CBS Starting TiWorker initialization.
2021-01-12 21:22:58, Info CBS Ending TiWorker initialization.
2021-01-12 21:22:58, Info CBS Starting the TiWorker main loop.
2021-01-12 21:22:58, Info CBS TiWorker starts successfully.
2021-01-12 21:22:58, Info CBS Universal Time is: 2021-01-12 20:22:58.952
2021-01-12 21:22:58, Info CBS Loaded Servicing Stack v6.3.9600.19750 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.3.9600.19750_none_fa39f32f9b2d0928\cbscore.dll
2021-01-12 21:22:58, Info CSI
[email protected]/1/12:20:22:58.952 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7ff80b957f79 @0x7ff813d13fe4 @0x7ff813d135eb @0x7ff64d68d69a @0x7ff64d68df4f @0x7ff832e92053)
2021-01-12 21:22:58, Info CBS SQM: Initializing online with Windows opt-in: False
2021-01-12 21:22:58, Info CBS SQM: Cleaning up report files older than 10 days.
2021-01-12 21:22:58, Info CBS SQM: Requesting upload of all unsent reports.
2021-01-12 21:22:58, Info CBS SQM: Failed to start upload with file pattern: C:\WINDOWS\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:22:58, Info CBS SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:22:58, Info CBS SQM: Queued 0 file(s) for upload with pattern: C:\WINDOWS\servicing\sqm\*_all.sqm, flags: 0x6
2021-01-12 21:22:58, Info CBS SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:22:58, Info CBS NonStart: Set pending store consistency check.
2021-01-12 21:22:58, Info CBS Session: 30861600_3087294753 initialized by client WindowsUpdateAgent.
2021-01-12 21:24:58, Info CBS Trusted Installer successfully registered to be restarted for pre-shutdown
2021-01-12 21:24:58, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2021-01-12 21:24:58, Info CBS TiWorker signaled for shutdown, going to exit.
2021-01-12 21:24:58, Info CBS Ending the TiWorker main loop.
2021-01-12 21:24:58, Info CBS Ending the TrustedInstaller main loop.
2021-01-12 21:24:58, Info CBS Starting TiWorker finalization.
2021-01-12 21:24:58, Info CBS Starting TrustedInstaller finalization.
2021-01-12 21:24:58, Info CBS Ending TrustedInstaller finalization.
2021-01-12 21:24:58, Info CBS Ending TiWorker finalization.
2021-01-12 21:36:20, Info CBS TI: --- Initializing Trusted Installer ---
2021-01-12 21:36:20, Info CBS TI: Last boot time: 2021-01-12 19:08:45.490
2021-01-12 21:36:20, Info CBS TI: Anticipating that shutdown processing will be required.
2021-01-12 21:36:20, Info CBS Starting TrustedInstaller initialization.
2021-01-12 21:36:20, Info CBS Ending TrustedInstaller initialization.
2021-01-12 21:36:20, Info CBS Starting the TrustedInstaller main loop.
2021-01-12 21:36:20, Info CBS TrustedInstaller service starts successfully.
2021-01-12 21:36:20, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2021-01-12 21:36:20, Info CBS Startup processing thread terminated normally
2021-01-12 21:36:21, Info CBS Starting TiWorker initialization.
2021-01-12 21:36:21, Info CBS Ending TiWorker initialization.
2021-01-12 21:36:21, Info CBS Starting the TiWorker main loop.
2021-01-12 21:36:21, Info CBS TiWorker starts successfully.
2021-01-12 21:36:21, Info CBS Universal Time is: 2021-01-12 20:36:21.386
2021-01-12 21:36:21, Info CBS Loaded Servicing Stack v6.3.9600.19750 with Core: C:\WINDOWS\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.3.9600.19750_none_fa39f32f9b2d0928\cbscore.dll
2021-01-12 21:36:21, Info CSI
[email protected]/1/12:20:36:21.402 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7ff80b957f79 @0x7ff813d13fe4 @0x7ff813d135eb @0x7ff64d68d69a @0x7ff64d68df4f @0x7ff832e92053)
2021-01-12 21:36:21, Info CBS SQM: Initializing online with Windows opt-in: False
2021-01-12 21:36:21, Info CBS SQM: Cleaning up report files older than 10 days.
2021-01-12 21:36:21, Info CBS SQM: Requesting upload of all unsent reports.
2021-01-12 21:36:21, Info CBS SQM: Failed to start upload with file pattern: C:\WINDOWS\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:36:21, Info CBS SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:36:21, Info CBS SQM: Queued 0 file(s) for upload with pattern: C:\WINDOWS\servicing\sqm\*_all.sqm, flags: 0x6
2021-01-12 21:36:21, Info CBS SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2021-01-12 21:36:21, Info CBS NonStart: Set pending store consistency check.
2021-01-12 21:36:21, Info CBS Session: 30861602_2522012061 initialized by client WindowsUpdateAgent.
2021-01-12 21:38:28, Info CBS Trusted Installer successfully registered to be restarted for pre-shutdown
2021-01-12 21:38:28, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP
2021-01-12 21:38:28, Info CBS TiWorker signaled for shutdown, going to exit.
2021-01-12 21:38:28, Info CBS Ending the TiWorker main loop.
2021-01-12 21:38:28, Info CBS Starting TiWorker finalization.
2021-01-12 21:38:28, Info CBS Ending the TrustedInstaller main loop.
2021-01-12 21:38:28, Info CBS Starting TrustedInstaller finalization.
2021-01-12 21:38:28, Info CBS Ending TrustedInstaller finalization.
2021-01-12 21:38:28, Info CBS Ending TiWorker finalization.
