Das steht in der XFree86.0.log:
XFree86 Version 4.2.0 / X Window System
(protocol Version 11, revision 0, vendor release 6600)
Release Date: 23 January 2002
If the server is older than 6-12 months, or if your card is
newer than the above date, look for a newer version before
reporting problems. (See
http://www.XFree86.Org/)
Build Operating System: SuSE Linux [ELF] SuSE
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/XFree86.0.log", Time: Wed Oct 9 15:08:05 2002
(==) Using config file: "/etc/X11/XF86Config"
(==) ServerLayout "Layout[all]"
(**) |-->Screen "Screen[0]" (0)
(**) | |-->Monitor "Monitor[0]"
(**) | |-->Device "Device[0]"
(**) |-->Input Device "Keyboard[0]"
(**) Option "Protocol" "Standard"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc104"
(**) XKB: model: "pc104"
(**) Option "XkbLayout" "de"
(**) XKB: layout: "de"
(**) Option "XkbVariant" "nodeadkeys"
(**) XKB: variant: "nodeadkeys"
(==) Keyboard: CustomKeycode disabled
(**) |-->Input Device "Mouse[1]"
(WW) The directory "/usr/X11R6/lib/X11/fonts/PEX" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/latin2/75dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/latin2/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/latin2/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/latin7/75dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/baekmuk" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/japanese" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/ucs/misc" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/ucs/75dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/ucs/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/hellas/misc" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/hellas/75dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/hellas/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/hellas/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc/sgi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/xtest" does not exist.
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/misc:unscaled,/usr/X11R6/lib/X11/fonts/local,/usr/X11R6/lib/X11/fonts/75dpi:unscaled,/usr/X11R6/lib/X11/fonts/100dpi:unscaled,/usr/X11R6/lib/X11/fonts/Type1,/usr/X11R6/lib/X11/fonts/URW,/usr/X11R6/lib/X11/fonts/Speedo,/usr/X11R6/lib/X11/fonts/latin2/misc:unscaled,/usr/X11R6/lib/X11/fonts/kwintv:unscaled,/usr/X11R6/lib/X11/fonts/truetype,/usr/X11R6/lib/X11/fonts/uni:unscaled,/usr/X11R6/lib/X11/fonts/CID"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(**) ModulePath set to "/usr/X11R6/lib/modules"
(**) Option "AllowMouseOpenFail"
(++) using VT number 7
(II) Open APM successful
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.1
XFree86 Video Driver: 0.5
XFree86 XInput driver : 0.3
XFree86 Server Extension : 0.1
XFree86 Font Renderer : 0.3
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.3
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 0.1.0
ABI class: XFree86 Video Driver, version 0.5
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x8000400c, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,3099 card 1106,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,b099 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:08:0: chip 13f6,0111 card 13f6,0111 rev 10 class 04,01,00 hdr 00
(II) PCI: 00:0a:0: chip 10b7,9200 card 10b7,1000 rev 74 class 02,00,00 hdr 00
(II) PCI: 00:10:0: chip 1106,3038 card 1106,3038 rev 80 class 0c,03,00 hdr 80
(II) PCI: 00:10:1: chip 1106,3038 card 1106,3038 rev 80 class 0c,03,00 hdr 80
(II) PCI: 00:10:2: chip 1106,3038 card 1106,3038 rev 80 class 0c,03,00 hdr 80
(II) PCI: 00:10:3: chip 1106,3104 card 1106,3104 rev 82 class 0c,03,20 hdr 00
(II) PCI: 00:11:0: chip 1106,3177 card 1106,0000 rev 00 class 06,01,00 hdr 80
(II) PCI: 00:11:1: chip 1106,0571 card 1106,0571 rev 06 class 01,01,8a hdr 00
(II) PCI: 01:00:0: chip 10de,0101 card 1043,400a rev 10 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0x00000000 - 0x0000ffff (0x10000) IX
(II) Bus 0 non-prefetchable memory range:
[0] -1 0x00000000 - 0xffffffff (0x0) MX
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0c (VGA_EN is set)
(II) Bus 1 I/O range:
(II) Bus 1 non-prefetchable memory range:
[0] -1 0xdde00000 - 0xdfefffff (0x2100000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0xcdc00000 - 0xddcfffff (0x10100000) MX
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:17:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(--) PCI:*(1:0:0) NVidia GeForce DDR rev 16, Mem @ 0xde000000/24, 0xd0000000/27, BIOS @ 0xdfef0000/16
(II) Addressable bus resource ranges are
[1] -1 0x00000000 - 0x0000ffff (0x10000) IX
(II) OS-reported resource ranges:
[0] -1 0xffe00000 - 0xffffffff (0x200000) MX(B)
[1] -1 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[2] -1 0x000f0000 - 0x000fffff (0x10000) MX
[3] -1 0x000c0000 - 0x000effff (0x30000) MX
[4] -1 0x00000000 - 0x0009ffff (0xa0000) MX
[5] -1 0x0000ffff - 0x0000ffff (0x1) IX
[6] -1 0x00000000 - 0x000000ff (0x100) IX
(II) Active PCI resource ranges:
[0] -1 0xdffffe00 - 0xdffffeff (0x100) MX
[1] -1 0xdfffff80 - 0xdfffffff (0x80) MX
[2] -1 0xe0000000 - 0xe3ffffff (0x4000000) MX
[3] -1 0xdfef0000 - 0xdfefffff (0x10000) MX(B)
[4] -1 0xd0000000 - 0xd7ffffff (0x8000000) MX(B)
[5] -1 0xde000000 - 0xdeffffff (0x1000000) MX(B)
[6] -1 0x0000fc00 - 0x0000fc0f (0x10) IX
[7] -1 0x0000e400 - 0x0000e41f (0x20) IX
[8] -1 0x0000e000 - 0x0000e01f (0x20) IX
[9] -1 0x0000dc00 - 0x0000dc1f (0x20) IX
[10] -1 0x0000e800 - 0x0000e87f (0x80) IX
[11] -1 0x0000ec00 - 0x0000ecff (0x100) IX
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0xdffffe00 - 0xdffffeff (0x100) MX
[6] -1 0xdfffff80 - 0xdfffffff (0x80) MX
[7] -1 0xe0000000 - 0xe3ffffff (0x4000000) MX
[8] -1 0xdfef0000 - 0xdfefffff (0x10000) MX(B)
[9] -1 0xd0000000 - 0xd7ffffff (0x8000000) MX(B)
[10] -1 0xde000000 - 0xdeffffff (0x1000000) MX(B)
[11] -1 0x0000ffff - 0x0000ffff (0x1) IX
[12] -1 0x00000000 - 0x000000ff (0x100) IX
[13] -1 0x0000fc00 - 0x0000fc0f (0x10) IX
[14] -1 0x0000e400 - 0x0000e41f (0x20) IX
[15] -1 0x0000e000 - 0x0000e01f (0x20) IX
[16] -1 0x0000dc00 - 0x0000dc1f (0x20) IX
[17] -1 0x0000e800 - 0x0000e87f (0x80) IX
[18] -1 0x0000ec00 - 0x0000ecff (0x100) IX
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.1.10
(II) Loading font FreeType
(II) LoadModule: "speedo"
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
(II) Module speedo: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.0.1
(II) Loading font Speedo
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
Module class: XFree86 Server Extension
ABI class: XFree86 Server Extension, version 0.1
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.3123
(II) Loading extension GLX
(II) LoadModule: "nvidia"
(II) Loading /usr/X11R6/lib/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.3
(II) NVIDIA XFree86 Driver 1.0-3123 Tue Aug 27 16:00:08 PDT 2002
(II) NVIDIA: NVIDIA driver for: RIVA TNT, RIVA TNT2, Vanta,
RIVA TNT2 Ultra, RIVA TNT2 Model 64, Aladdin TNT2, GeForce 256,
GeForce DDR, Quadro, GeForce2 MX/MX 400, GeForce2 MX 100/200,
Quadro2 MXR/EX/Go, GeForce2 Integrated GPU, GeForce2 GTS,
GeForce2 Ti, GeForce2 Ultra, Quadro2 Pro, GeForce4 MX 460,
GeForce4 MX 440, GeForce4 MX 420, Quadro4 500/550 XGL,
Quadro4 200/400 NVS, NV18, NV18 , NV18 , NV18, NV18GL, NV18GL ,
NV18GL , 0x01F0, GeForce3, GeForce3 Ti 200, GeForce3 Ti 500,
Quadro DCC, GeForce4 Ti 4600, GeForce4 Ti 4400, GeForce4 Ti 4200,
Quadro4 900 XGL, Quadro4 750 XGL, Quadro4 700 XGL, NV28, NV28 ,
NV28GL, NV28GL , GeForce2 Go, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, GeForce4 440 Go 64M,
GeForce4 410 Go 16M, Quadro4 500 GoGL
(II) Primary Device is: PCI 01:00:0
(--) Chipset GeForce DDR found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[11] 0 0x000a0000 - 0x000affff (0x10000) MS
[12] 0 0x000b0000 - 0x000b7fff (0x8000) MS
[13] 0 0x000b8000 - 0x000bffff (0x8000) MS
[14] -1 0x0000ffff - 0x0000ffff (0x1) IX
[15] -1 0x00000000 - 0x000000ff (0x100) IX
[16] -1 0x0000fc00 - 0x0000fc0f (0x10) IX
[17] -1 0x0000e400 - 0x0000e41f (0x20) IX
[18] -1 0x0000e000 - 0x0000e01f (0x20) IX
[19] -1 0x0000dc00 - 0x0000dc1f (0x20) IX
[20] -1 0x0000e800 - 0x0000e87f (0x80) IX
[21] -1 0x0000ec00 - 0x0000ecff (0x100) IX
[22] 0 0x000003b0 - 0x000003bb (0xc) IS
[23] 0 0x000003c0 - 0x000003df (0x20) IS
(II) Setting vga for screen 0.
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
(**) NVIDIA(0): Depth 16, (--) framebuffer bpp 16
(==) NVIDIA(0): RGB weight 565
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(--) NVIDIA(0): Linear framebuffer at 0xD0000000
(--) NVIDIA(0): MMIO registers at 0xDE000000
(--) NVIDIA(0): VideoRAM: 32768 kBytes
(--) NVIDIA(0): Detected TV Encoder: Chrontel 7005
(--) NVIDIA(0): Display 0: maximum pixel clock at 8 bpp: 350 MHz
(--) NVIDIA(0): Display 0: maximum pixel clock at 16 bpp: 350 MHz
(--) NVIDIA(0): Display 0: maximum pixel clock at 32 bpp: 300 MHz
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) NVIDIA(0): Monitor[0]: Using hsync range of 30.00-96.00 kHz
(II) NVIDIA(0): Monitor[0]: Using vrefresh range of 50.00-160.00 Hz
(II) NVIDIA(0): Clock range: 12.00 to 350.00 MHz
(II) NVIDIA(0): Not using default mode "1600x1200" (hsync out of range)
(II) NVIDIA(0): Not using default mode "800x600" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1792x1344" (hsync out of range)
(II) NVIDIA(0): Not using default mode "896x672" (hsync out of range)
(WW) (1856x1392,Monitor[0]) mode clock 218.3MHz exceeds DDC maximum 210MHz
(II) NVIDIA(0): Not using default mode "1856x1392" (hsync out of range)
(II) NVIDIA(0): Not using default mode "928x696" (hsync out of range)
(WW) (1920x1440,Monitor[0]) mode clock 234MHz exceeds DDC maximum 210MHz
(II) NVIDIA(0): Not using default mode "1920x1440" (hsync out of range)
(II) NVIDIA(0): Not using default mode "960x720" (hsync out of range)
(II) NVIDIA(0): Not using mode "1024x768" (no mode of this name)
(**) NVIDIA(0): Validated modes for Display Device 0:
(**) NVIDIA(0): Default mode "1280x1024": 157.5 MHz, 91.1 kHz, 85.0 Hz
(**) NVIDIA(0): Default mode "1280x1024": 135.0 MHz, 80.0 kHz, 75.0 Hz
(**) NVIDIA(0): Mode "1024x768": 78.7 MHz, 59.9 kHz, 75.7 Hz
(**) NVIDIA(0): Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(**) NVIDIA(0): Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
(**) NVIDIA(0): Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) NVIDIA(0): Default mode "640x480": 74.2 MHz, 85.9 kHz, 85.1 Hz (D)
(**) NVIDIA(0): Default mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
(**) NVIDIA(0): Default mode "720x400": 35.5 MHz, 37.9 kHz, 85.0 Hz
(II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
(**) NVIDIA(0): Display dimensions: (360, 270) mm
(**) NVIDIA(0): DPI set to (90, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
ABI class: XFree86 ANSI C Emulation, version 0.1
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/X11R6/lib/modules/libxaa.a
(II) Module xaa: vendor="The XFree86 Project"
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor="The XFree86 Project"
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0xd0000000 - 0xd7ffffff (0x8000000) MX
[1] 0 0xde000000 - 0xdeffffff (0x1000000) MX
[2] -1 0xffe00000 - 0xffffffff (0x200000) MX(B)
[3] -1 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[4] -1 0x000f0000 - 0x000fffff (0x10000) MX
[5] -1 0x000c0000 - 0x000effff (0x30000) MX
[6] -1 0x00000000 - 0x0009ffff (0xa0000) MX
[7] -1 0xdffffe00 - 0xdffffeff (0x100) MX
[8] -1 0xdfffff80 - 0xdfffffff (0x80) MX
[9] -1 0xe0000000 - 0xe3ffffff (0x4000000) MX
[10] -1 0xdfef0000 - 0xdfefffff (0x10000) MX(B)
[11] -1 0xd0000000 - 0xd7ffffff (0x8000000) MX(B)
[12] -1 0xde000000 - 0xdeffffff (0x1000000) MX(B)
[13] 0 0x000a0000 - 0x000affff (0x10000) MS(OprD)
[14] 0 0x000b0000 - 0x000b7fff (0x8000) MS(OprD)
[15] 0 0x000b8000 - 0x000bffff (0x8000) MS(OprD)
[16] -1 0x0000ffff - 0x0000ffff (0x1) IX
[17] -1 0x00000000 - 0x000000ff (0x100) IX
[18] -1 0x0000fc00 - 0x0000fc0f (0x10) IX
[19] -1 0x0000e400 - 0x0000e41f (0x20) IX
[20] -1 0x0000e000 - 0x0000e01f (0x20) IX
[21] -1 0x0000dc00 - 0x0000dc1f (0x20) IX
[22] -1 0x0000e800 - 0x0000e87f (0x80) IX
[23] -1 0x0000ec00 - 0x0000ecff (0x100) IX
[24] 0 0x000003b0 - 0x000003bb (0xc) IS(OprU)
[25] 0 0x000003c0 - 0x000003df (0x20) IS(OprU)
(II) NVIDIA(0): AGP 4X successfully initialized
(II) NVIDIA(0): Setting mode "1280x1024"
(II) NVIDIA(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
Solid filled trapezoids
8x8 mono pattern filled rectangles
8x8 mono pattern filled trapezoids
Indirect CPU to Screen color expansion
Solid Lines
Scanline Image Writes
Offscreen Pixmaps
Driver provided FillSolidRects replacement
Driver provided FillSolidSpans replacement
Driver provided FillMono8x8PatternRects replacement
Driver provided WritePixmap replacement
Driver provided ReadPixmap replacement
Setting up tile and stipple cache:
20 128x128 slots
5 256x256 slots
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-GLX
(II) Loading extension NV-CONTROL
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension RENDER
(II) [GLX]: Calling GlxExtensionInit
(II) Keyboard "Keyboard[0]" handled by legacy driver
(**) Option "Protocol" "imps/2"
(**) Mouse[1]: Protocol: "imps/2"
(**) Option "CorePointer"
(**) Mouse[1]: Core Pointer
(**) Option "Device" "/dev/mouse"
(**) Option "ZAxisMapping" "4 5"
(**) Mouse[1]: ZAxisMapping: buttons 4 and 5
(**) Mouse[1]: Buttons: 5
(II) XINPUT: Adding extended input device "Mouse[1]" (type: MOUSE)
