- Dabei seit
- 20.09.2016
- Beiträge
- 94.182
LG PF1500G - Surface Book Pro
For some time (I do not know since when - maybe one year) I cannot connect my Surface Book with an LG PF1500G projector.
The projector is working, I have tested with two other windows 10 systems.
When I try to "connect with wireless display" the beamer is found but when I try to connect I get the message
"Couldn't connect to your device" while Beamer shows "Signal detection". The beamer has two states when no connection is done I see "no signal", when a connection is initiated "Signal detection" is shown.
When removing the projector I would expect that Windows prompts me to enter the code (first handshake) of the projector but it does not.
No events found in event log, no other error message.
This means to me:
- Both devices see each other
- Something goes wrong while "protocol negotiation"
I tried the following:
- Update of the OS, the system is up to date (2019-03-07)
- I reinstalled and removed all WiFi drivers (Marvell AVASTAR Wireless-AC Network Controller)
- Network reset
- Removed hidden miracast devices and reinstalled the
- Removed the projector
AMAZING!
winver: Version 1809 (OS Build 17763.348)
dxdiag:
System Information
Time of this report: 3/7/2019, 19:20:31
Machine name: xxx
Machine Id: xxx
Operating System: Windows 10 Pro 64-bit (10.0, Build 17763) (17763.rs5_release.180914-1434)
Language: German (Regional Setting: German)
System Manufacturer: Microsoft Corporation
System Model: Surface Book
BIOS: 91.2439.769 (type: UEFI)
Processor: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz (4 CPUs), ~2.8GHz
Memory: 16384MB RAM
Available OS Memory: 16310MB RAM
Page File: 4195MB used, 14545MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 192 DPI (200 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Supported
DxDiag Version: 10.00.17763.0001 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Display Tab 3: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 520
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_8086&DEV_1916&SUBSYS_00141414&REV_07
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 8282 MB
Dedicated Memory: 128 MB
Shared Memory: 8154 MB
Current Mode: 3440 x 1440 (32 bit) (59Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.651367,0.332031), Green(0.306641,0.630859), Blue(0.150391,0.059570), White Point(0.313477,0.329102)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: LG ULTRAWIDE WQHD(HDMI)
Monitor Model: LG ULTRAWIDE
Monitor Id: GSM76F6
Native Mode: 3440 x 1440(p) (59.973Hz)
Output Type: Displayport External
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\64gh6293.inf_amd64_22fd****edd17f\igd12umd64.dll
Driver File Version: 24.20.0100.6293 (English)
Driver Version: 24.20.100.6293
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.1
Graphics Preemption: Triangle
Compute Preemption: Thread
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Virtualization: Not Supported
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:False
Driver Attributes: Final Retail
Driver Date/Size: 26.09.2018 01:00:00, 2018392 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-5A56-11CF-316F-7020BCC2D535}
Vendor ID: 0x8086
Device ID: 0x1916
SubSys ID: 0x00141414
Revision ID: 0x0007
Driver Strong Name: oem68.inf:5f63e534f36b7c6d:iSKLD_w10_DS:24.20.100.6293
ci\ven_8086&dev_1916&subsys_00141414
Rank Of Driver: 00D10001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 3
MPO Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB
MPO Stretch: 5.000X - 0.334X
MPO Media Hints:
MPO Formats: YUY2,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
PanelFitter Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB
PanelFitter Stretch: 5.000X - 0.334X
Card name: NVIDIA GeForce GPU
Manufacturer: NVIDIA
Chip type: GeForce GPU
DAC type: Integrated RAMDAC
Device Type: Render-Only Device
Device Key: Enum\PCI\VEN_10DE&DEV_134B&SUBSYS_00081414&REV_A2
Device Status: 0180600A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_REMOVABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Display Memory: 9141 MB
Dedicated Memory: 987 MB
Current Mode: Unknown
HDR Support: Unknown
Display Topology: Unknown
Display Color Space: Unknown
Color Primaries: Unknown
Display Luminance: Unknown
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nvmso.inf_amd64_8461c3207f0421af\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvmso.inf_amd64_8461c3207f0421af\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvmso.inf_amd64_8461c3207f0421af\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvmso.inf_amd64_8461c3207f0421af\nvldumdx.dll
Driver File Version: 23.21.0013.9140 (English)
Driver Version: 23.21.13.9140
DDI Version: 12
Feature Levels: 11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.3
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Discrete
Driver Date/Size: 04.04.2018 01:00:00, 949016 bytes
WHQL Logo'd: Yes
Device Identifier: Unknown
Vendor ID: 0x10DE
Device ID: 0x134B
SubSys ID: 0x00081414
Revision ID: 0x00A2
Driver Strong Name: oem28.inf:0f066de33a5006bf:Section002:23.21.13.9140
ci\ven_10de&dev_134b&subsys_00081414
Video Accel: Unknown
DXVA2 Modes: Unknown
Deinterlace Caps: n/a
D3D9 Overlay: Unknown
DXVA-HD: Unknown
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 0
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
PanelFitter Caps: Not Supported
PanelFitter Stretch: Not Supported
Card name: Miracast display port driver V3
Manufacturer: LGE
Chip type: Unknown
DAC type: Unknown
Device Type: Display-Only Device
Device Key: Enum\SWD\WIFIDIRECT
Display Memory: 8154 MB
Dedicated Memory: 0 MB
Driver Name: c:\windows\system32\drivers\umdf\miradisp.dll,c:\windows\system32\drivers\wudfrd.sys
Driver File Version: 10.00.17763.0001 (English)
Driver Version: 10.0.17763.1
DDI Version: 12
Driver Model: WDDM 1.3
Miracast: Supported
Hybrid Graphics GPU: Not Supported
Catalog Attributes: N/A
Driver Date/Size: 21.06.2006 01:00:00, 443392 bytes
WHQL Logo'd: Yes
Vendor ID: 0x1414
Device ID: 0x008C
SubSys ID: 0x00000000
Revision ID: 0x0000
Driver Strong Name: miradisp.inf:53c2dc9353c2dc93:MiraDisp_Inst:10.0.17763.1:WFD\MiracastDisplayDevice
Rank Of Driver: 00FF2000
DXVA-HD: Unknown
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 0
This means to me:
- Network reset
AMAZING!
dxdiag:
System Information
Machine name: xxx
Machine Id: xxx
Memory: 16384MB RAM
DxDiag Notes
Display Devices
DAC type: Internal
Monitor Id: GSM76F6
DDI Version: 12
Miracast: Supported
WHQL Logo'd: Yes
Vendor ID: 0x8086
Device ID: 0x1916
Revision ID: 0x0007
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 3
MPO Media Hints:
DDI Version: 12
WHQL Logo'd: Yes
Vendor ID: 0x10DE
Device ID: 0x134B
Revision ID: 0x00A2
DXVA-HD: Unknown
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 0
Manufacturer: LGE
Chip type: Unknown
DAC type: Unknown
DDI Version: 12
Miracast: Supported
WHQL Logo'd: Yes
Vendor ID: 0x1414
Device ID: 0x008C
Revision ID: 0x0000
DXVA-HD: Unknown
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 0
