GELÖST Programmierproblem (vermutlich Javascript)
Diskutiere Programmierproblem (vermutlich Javascript) im Programmierung Forum im Bereich Software Forum; Eine Frage an meine Board-Kollegen hier: Ich habe folgenden Code den ich ändern müsste und es selber nicht kann da ich nicht weiß wie. <div><div...
Erli
Erli
WB-TEAM / MOD
GB
Code:
<div><div id="countdownDiv" style="font-size:16px; font-weight:bold; text-align:center; width:100%;">
                <div id="countdownCountdown1035" style="font-family:monospace,courier; font-size:20px;"></div>
                <script>
                    var countdownStamp1035 = 1337968800;
                    function updateCountdown1035() {
                        var currTime = new Date();
                        var countdownSecs = countdownStamp1035 - parseInt(currTime.getTime() / 1000);
                        if(countdownSecs <= 0) {
                            // already elapsed
                            document.getElementById("countdownCountdown1035").style.display = "none";
                            document.getElementById("countdownUntil1035").innerHTML = "";
                            document.getElementById("countdownElapsed1035").style.display = "block";
                            if(CountdownInterval1035) {
                                clearInterval(CountdownInterval1035);
                                alert("Countdown abgelaufen!");
                        } else {
                            // show countdown
                            var seconds = parseInt(countdownSecs % 60);
                            countdownSecs = parseInt(countdownSecs / 60);
                            var minutes = parseInt(countdownSecs % 60);
                            var hours = parseInt(countdownSecs % 24);
                            var days = parseInt(countdownSecs / 24);
                            var str = "";
                            if(days > 1) {
                                str += days + " Tage, ";
                            } else if(days > 0) {
                                str += days + " Tag, ";
                            if(hours < 10) str += "0";
                            str += ""+hours+" : ";
                            if(minutes < 10) str += "0";
                            str += ""+minutes+" : ";
                            if(seconds < 10) str += "0";
                            str += ""+seconds;
                            document.getElementById("countdownCountdown1035").innerHTML = str;
                    var CountdownInterval1035 = window.setInterval("updateCountdown1035()", 200);
                </script>
                <div id="countdownElapsed1035" style="display:none">Countdown abgelaufen:</div>
                <div id="countdownUntil1035" style="font-size:16px; line-height:40px; height:40px">bis</div>
                <div>zum Lengdorfer Waldfest 2012 </div>
                </div></div>
Das soll ein Countdown sein der bis zum 25.05.2012 20:00 Uhr gelaufen ist. Danach kommt die Meldung Countdown abgelaufen.
Ich müsste jetzt das Datum 17.05.2013 ebenfalls 20 Uhr erzeugen/einfügen was auch immer.
Ich habe aber keine Ahnung wie der Code der das Datum beschreibt erzeugt wird? Im Beispiel oben vermutlich das hier
Vielleicht kann mir wer das erklären. Habe nämlich null Ahnung was ich da eigentlich mache :shame
Das ganze soll hier eingefügt werden.
:danke schon mal fürs lesen und beschäftigen :D
Erli
Quant
Quant
Habs nur kurz überschlagen, aber ja, das ist Java Script und ja so grob überschlagen, da musst du den Zeitstempel aktualisieren. In JavaScript wird genauso wie in Linux das Datum gespeichert, nämlich als vergangene Zeit (in Sekunden) seit Beginn des Unix-Jahres (01.01.1970). Am besten du schaust dir hierzu ne Objektreferenz an bsp.weise http://de.selfhtml.org/javascript/objekte/date.htm .
Wenn du was nicht verstehst, schreib einfach nochmal hier. Ansonsten einfach den Zahlenwert durch 1368813600 ersetzen. Also 1337968800 => 1368813600
dann müsste alles klappen, sofern das Script vorher auch gelaufen ist^^
Erli
Erli
WB-TEAM / MOD
GB
das Verlinkte verstehe ich nicht (habe absolut keine Ahnung davon) allerdings verstehe ich den Ansatz mit den Sekunden seit 01.01.1970.
:danke Du hast mir sehr geholfen :up
Erli :cool
Quant
Quant
:aah noch 348 Tage
es funktioniert :up
ach ne;
@Erli:
Ist nicht so schwer. Es werden einfach ein paar Divs mit ID erzeugt. In diese werden dann die aktuellen Infos mit document.getElementById('... Id des Objektes ...').innerHTML geschrieben.
und mit window.setInterval("updateCountdown1035()", 200); wird sichergestellt, dass die Funktion alle 200ms aufgerufen wird, also jede 1/5. Sekunde. Übrigens kann man euren Code vermutlich in die irre führen, wenn man auf den eigenem PC eine andere Zeit gesetzt hat. (JavaScript ließt bei den meisten Browsern die Zeit/Zeiteinstellungen am eigenen Rechner aus)
Sobald dich die ganze Geschichte mehr interessiert, unter http://www.kostenlose-javascripts.de/tutorials/tutorials/datumsfunktionen.html gibt es eine "Zusammenfassung"; Beispiele dazu
Programmierproblem (vermutlich Javascript) - Ähnliche Themen
  • PC scrollt von alleine auch ohne Maus, vermutlich seit Update 1909
    PC scrollt von alleine auch ohne Maus, vermutlich seit Update 1909: Hallo Leute, ich habe folgendes Problem, seit zirka 3 Tagen Scrollt mein Pc von alleine auch mit abgesteckten USB Geräten incl Maus. Habe den...
  • (vermutlich) seit dem Update "Bad owner or permissions on C: \\ Users \\ nnn / .ssh / config"
    (vermutlich) seit dem Update "Bad owner or permissions on C: \\ Users \\ nnn / .ssh / config": OpenSSH- Serverkonfiguration unter Windows10 .ssh \ config Ich erhalte die Meldung I get the message "Bad owner or permissions on C: \\ Users \\...
  • Verschiedene Bluescreens - Win10 - Defekt eingrenzen, vermutlich Treiberfehler
    Verschiedene Bluescreens - Win10 - Defekt eingrenzen, vermutlich Treiberfehler: Hallo zusammen, ich hoffe jemand kann mir helfen. Ich habe mir ein neues PC-System zusammen gestellt. Und habe seit einen Test von Prime95, das...
  • Firefox kann nicht als Stabdartbrowser gesetzt werden, vermutlich zum 100. mal...
    Firefox kann nicht als Stabdartbrowser gesetzt werden, vermutlich zum 100. mal...: Hallöle liebe Community Ich habe, mittlerweile seit Monaten das Problem das ich Firefox nicht (mehr) als Standartapp setzen kann. Vorher war FF...
