Probleme mit MRTG
Diskutiere Probleme mit MRTG im Linux Forum im Bereich Weitere Betriebssysteme; Hallo, in diesem Tutorial habe ich einfahc mal bei mir auf den Server gezogen und etwas bearbeitet. Nun sieht meine Config so aus: Aber leider...
computerexperte06
31
Lüneburg
# Created by
# /usr/bin/cfgmaker [email protected]
### Global Config Options
# for UNIX
# WorkDir: /home/http/mrtg
# for Debian
WorkDir: /var/www/virtual/eplay-tv.de/status/htdocs
# or for NT
# WorkDir: c:\mrtgdata
### Global Defaults
# to get bits instead of bytes and graphs growing to the right
# Options[_]: growright, bits
EnableIPv6: no
# System: ksxxxxxx.kimsufi.com
# Description: Linux ksxxxxxx.kimsufi.com 2.6.38.2-grsec-xxxx-grs-ipv6-64 #2 SMP Thu Aug 25 16:40:22 UTC 2011 x86_64
# Contact: Me <[email protected]>
# Location: Sitting on the Dock of the Bay
### Interface 2 >> Descr: 'eth0' | Name: '' | Ip: '94.xx.xxx.20' | Eth: 'e0:69:95:d7:9b:1f' ###
Target[localhost_eth0]: \eth0:p[email protected]:
SetEnv[localhost_eth0]: MRTG_INT_IP="94.xx.xxx.20" MRTG_INT_DESCR="eth0"
MaxBytes[localhost_eth0]: 12500000
Title[localhost_eth0]: 94.xx.xxx.20 -- ksxxxxxx.kimsufi.com
Options[localhost_eth0]: growright,nopercent,nobanner,noinfo
PageTop[localhost_eth0]: <H1>94.xx.xxx.20 -- ks383295.kimsufi.com</H1>
# <TABLE>
# <TR><TD>System:</TD> <TD>ksxxxxxx.kimsufi.com in LAN</TD></TR>
# <TR><TD>Maintainer:</TD> <TD>flix <[email protected]></TD></TR>
# <TR><TD>Description:</TD><TD>eth0 </TD></TR>
# <TR><TD>ifType:</TD> <TD>ethernet</TD></TR>
# <TR><TD>ifName:</TD> <TD></TD></TR>
# <TR><TD>Max Speed:</TD> <TD>100.0 Mbits/s</TD></TR>
# <TR><TD>Ip:</TD> <TD>94.xx.xxx.20 (ksxxxxxx.kimsufi.com)</TD></TR>
# </TABLE>
### End of ksxxxxxx.kimsufi.com
### CPU Load
LoadMIBs: /usr/share/snmp/mibs/UCD-SNMP-MIB.txt
Target[localhost.cpu]:ssCpuRawUser.0&ssCpuRawUser.0:p[email protected]+ ssCpuRawSystem.0&ssCpuRawSystem.0:p[email protected]+ ssCpuRawNice.0&ssCpuRawNice.0:p[email protected]
MaxBytes[localhost.cpu]: 100
Title[localhost.cpu]: CPU Load
PageTop[localhost.cpu]: <H1>Active CPU Load %</H1>
Unscaled[localhost.cpu]: ymwd
ShortLegend[localhost.cpu]: %
YLegend[localhost.cpu]: CPU Utilization
Legend1[localhost.cpu]: Active CPU in % (Load)
Legend2[localhost.cpu]:
Legend3[localhost.cpu]:
Legend4[localhost.cpu]:
LegendI[localhost.cpu]: Active
LegendO[localhost.cpu]:
Options[localhost.cpu]: growright,nopercent,nobanner
### Memory Free
LoadMIBs: /usr/share/snmp/mibs/HOST-RESOURCES-MIB.txt
Target[localhost.mem]: .1.3.6.1.4.1.2021.4.6.0&.1.3.6.1.4.1.2021.4.6.0:p[email protected]
PageTop[localhost.mem]: <H1>Free Memory</H1>
Options[localhost.mem]: nopercent,growright,gauge,noinfo,nobanner
Title[localhost.mem]: Free Memory
MaxBytes[localhost.mem]: 1000000
kMG[localhost.mem]: k,M,G,T,P,X
YLegend[localhost.mem]: bytes
ShortLegend[localhost.mem]: bytes
LegendI[localhost.mem]: Free Memory:
LegendO[localhost.mem]:
Legend1[localhost.mem]: Free memory, not including swap, in bytes
### Disk Free in Percent
Target[localhost.dfpercent]: dskPercent.3&dskPercent.1:p[email protected]
MaxBytes[localhost.dfpercent]: 100
Title[localhost.dfpercent]: DISK USAGE
PageTop[localhost.dfpercent]: <H1>Disk root and home Usage %</H1>
Unscaled[localhost.dfpercent]: ymwd
ShortLegend[localhost.dfpercent]: %
YLegend[localhost.dfpercent]: Disk Utilization
Legend1[localhost.dfpercent]: home disk
Legend2[localhost.dfpercent]: root disk
Legend3[localhost.dfpercent]:
Legend4[localhost.dfpercent]:
LegendI[localhost.dfpercent]: home disk
LegendO[localhost.dfpercent]: root disk
Options[localhost.dfpercent]: growright,gauge,nopercent,noinfo,nobanner
### Swap Free
Target[localhost.swap]: memAvailSwap.0&memAvailSwap.0:p[email protected]
PageTop[localhost.swap]: <H1>Swap Memory Free</H1>
Options[localhost.swap]: nopercent,growright,gauge,noinfo,nobanner
Title[localhost.swap]: Free Memory
MaxBytes[localhost.swap]: 1000000
kMG[localhost.swap]: k,M,G,T,P,X
YLegend[localhost.swap]: bytes
ShortLegend[localhost.swap]: bytes
LegendI[localhost.swap]: Free Memory:
LegendO[localhost.swap]:
Legend1[localhost.swap]: Swap memory avail, in bytes
### Processes Running
Target[localhost.procs]: `/etc/mrtg/stat.pl procs root`
Options[localhost.procs]: nopercent,growright,gauge,nobanner,integer,noinfo
Title[localhost.procs]: Process
PageTop[localhost.procs]: <h1>Processes</h1>
MaxBytes[localhost.procs]: 5000000
YLegend[localhost.procs]: Processes
ShortLegend[localhost.procs]: procs
LegendI[localhost.procs]: Processes:
LegendO[localhost.procs]:
Legend1[localhost.procs]: Running Processes
### Logged-in Users
Target[localhost.users]: `/etc/mrtg/stat.pl users root`
Options[localhost.users]: nopercent,growright,gauge,integer,nobanner,noinfo
Title[localhost.users]: Logged-in users
PageTop[localhost.users]: <h1>Logged-in users</h1>
MaxBytes[localhost.users]: 60000
YLegend[localhost.users]: users
ShortLegend[localhost.users]: users
LegendI[localhost.users]: Users:
LegendO[localhost.users]:
Legend1[localhost.users]: Logged-in users
### Temperature
Title[localhost.temp]: Temperature on box
PageTop[localhost.temp]: <H1>Temperature</H1>
Target[localhost.temp]: `mrtg-sensors it87-isa-0290 temp3 it87-isa-0290 temp2`
Options[localhost.temp]: noinfo,gauge,growright,integer,nopercent,nobanner
Unscaled[localhost.temp]:dwmy
MaxBytes[localhost.temp]: 100
YLegend[localhost.temp]: °C
ShortLegend[localhost.temp]: °C
Legend1[localhost.temp]: CPU Temperature
Legend2[localhost.temp]: System Temperature
LegendI[localhost.temp]: CPU:
LegendO[localhost.temp]: System:
### Fan
Target[localhost.fan]: `mrtg-sensors it87-isa-0290 fan1`
MaxBytes[localhost.fan]: 4000
Options[localhost.fan]: noinfo,gauge,growright,integer,nopercent,nobanner
Title[localhost.fan]: System Fan Speed
PageTop[localhost.fan]: <H1>System Fan Speed (fan1)</H1>
YLegend[localhost.fan]: Rounds Per Minute
ShortLegend[localhost.fan]: RPM
LegendI[localhost.fan]: Speed:
LegendO[localhost.fan]:
Legend1[localhost.fan]: System Fan Speed
### Ping
Title[localhost.ping]: Ping Time
PageTop[localhost.ping]: <H1>Ping Time</H1>
Target[localhost.ping]: `/etc/mrtg/ping.sh`
MaxBytes[localhost.ping]: 2000
Options[localhost.ping]: growright,unknaszero,nopercent,gauge,nobanner,noinfo
LegendI[localhost.ping]: Pkt loss %
LegendO[localhost.ping]: Avg RTT
Legend1[localhost.ping]: Pkt loss %
Legend2[localhost.ping]: Avg RTT
YLegend[localhost.ping]: RTT (ms)
### Connectionuptime
Target[localhost.conuptime]: `/etc/mrtg/connectionuptime.sh`
Options[localhost.conuptime]: nopercent,growright,gauge,nobanner,integer,noinfo
Title[localhost.conuptime]: Connectionuptime
PageTop[localhost.conuptime]: <h1>Connectionuptime</h1>
MaxBytes[localhost.conuptime]: 780
YLegend[localhost.conuptime]: Minutes
ShortLegend[localhost.conuptime]: min
LegendI[localhost.conuptime]: Minutes:
LegendO[localhost.conuptime]:
Legend1[localhost.conuptime]: Connection uptime of ppp0 in minutes (720 mins are 12 hours)
### Uptime
Target[localhost.uptime]: `/etc/mrtg/uptime.sh`
Options[localhost.uptime]: nopercent,growright,gauge,nobanner,integer,noinfo
#Suppress[localhost.uptime]: d
Title[localhost.uptime]: Uptime
PageTop[localhost.uptime]: <h1>Uptime</h1>
MaxBytes[localhost.uptime]: 1000000
YLegend[localhost.uptime]: Days
ShortLegend[localhost.uptime]: days
LegendI[localhost.uptime]: Days:
LegendO[localhost.uptime]:
Legend1[localhost.uptime]: Uptime of Server in days
Aber leider funktioniert das nicht, denn es werden nur 4 Statistiken angezeigt und bekomme alle 5 Minuten eine Cron-Error. Hier der Log:
SNMP Error:
Received SNMP response with error code
error status: noSuchName
index 2 (OID: 1.3.6.1.2.1.2.2.1.16.0)
SNMPv1_Session (remote host: "localhost" [127.0.0.1].161)
community: "public"
request ID: 966596246
PDU bufsize: 8000 bytes
timeout: 2s
retries: 5
backoff: 1)
at /usr/share/perl5/SNMP_util.pm line 492
SNMPGET Problem for ifInOctets.0 ifOutOctets.0 sysUptime sysName on
[email protected]::::::v4only
at /usr/bin/mrtg line 2251
Unknown SNMP var ssCpuRawUser.0
2011-12-26 17:10:01: WARNING: Expected a number but got '0:09:27'
2011-12-26 17:10:01: WARNING: Expected a number but got 'ks383295.kimsufi.com'
Unknown SNMP var ssCpuRawSystem.0
Unknown SNMP var ssCpuRawNice.0
SNMP Error:
index 2 (OID: 1.3.6.1.4.1.2021.4.6.0)
community: "public"
request ID: 1809430528
timeout: 2s
retries: 5
backoff: 1)
SNMPGET Problem for .1.3.6.1.4.1.2021.4.6.0 .1.3.6.1.4.1.2021.4.6.0 sysUptime
sysName on [email protected]::::::v4only
Unknown SNMP var dskPercent.3
Unknown SNMP var dskPercent.1
Unknown SNMP var memAvailSwap.0
Can't exec "mrtg-sensors": No such file or directory at /usr/bin/mrtg line 2079.
2011-12-26 17:10:01: WARNING: Running 'mrtg-sensors it87-isa-0290 temp3
it87-isa-0290 temp2': No such file or directory
2011-12-26 17:10:01: WARNING: Could not get any data from external command
'mrtg-sensors it87-isa-0290 temp3 it87-isa-0290 temp2'
Maybe the external command did not even start. (No such file or directory)
2011-12-26 17:10:01: WARNING: Problem with External get 'mrtg-sensors it87-isa-0290
temp3 it87-isa-0290 temp2':
Expected a Number for 'in' but nothing'
Expected a Number for 'out' but nothing'
2011-12-26 17:10:01: WARNING: Running 'mrtg-sensors it87-isa-0290 fan1': No such
file or directory
fan1':
fan1':
2011-12-26 17:10:10: ERROR: Target[localhost_eth0][_IN_] 'eth $target->[0]{$mode} '
(kill): Can't call method "eth" on unblessed reference at (eval 19) line 1.
2011-12-26 17:10:10: ERROR: Target[localhost_eth0][_OUT_] 'eth $target->[0]{$mode} '
(kill): Can't call method "eth" on unblessed reference at (eval 20) line 1.
2011-12-26 17:10:10: ERROR: Target[localhost.cpu][_IN_] ' $target->[1]{$mode} +
$target->[2]{$mode} + $target->[3]{$mode} ' (warn): Use of uninitialized value in
addition (+) at (eval 22) line 1.
2011-12-26 17:10:10: ERROR: Target[localhost.cpu][_OUT_] ' $target->[1]{$mode} +
addition (+) at (eval 23) line 1.
2011-12-26 17:10:10: ERROR: Target[localhost.mem][_IN_] ' $target->[4]{$mode} ' did
not eval into defined data
2011-12-26 17:10:10: ERROR: Target[localhost.mem][_OUT_] ' $target->[4]{$mode} ' did
2011-12-26 17:10:10: ERROR: Target[localhost.dfpercent][_IN_] ' $target->[5]{$mode}
' did not eval into defined data
2011-12-26 17:10:10: ERROR: Target[localhost.dfpercent][_OUT_] ' $target->[5]{$mode}
2011-12-26 17:10:10: ERROR: Target[localhost.swap][_IN_] ' $target->[6]{$mode} ' did
2011-12-26 17:10:10: ERROR: Target[localhost.swap][_OUT_] ' $target->[6]{$mode} '
2011-12-26 17:10:10: ERROR: Target[localhost.temp][_IN_] ' $target->[9]{$mode} ' did
2011-12-26 17:10:10: ERROR: Target[localhost.temp][_OUT_] ' $target->[9]{$mode} '
2011-12-26 17:10:10: ERROR: Target[localhost.fan][_IN_] ' $target->[10]{$mode} ' did
2011-12-26 17:10:10: ERROR: Target[localhost.fan][_OUT_] ' $target->[10]{$mode} '
Wie kann ich das beheben?
Benny
PS:
Nutze Debian 6
So sieht es aktuell aus http://status.eplay-tv.de/
Probleme mit MRTG
Probleme mit MRTG - Ähnliche Themen
Dpc_ Watchdog Violation: Guten Tag Ich habe einen neuen Computer gekauft und erhalte seit Anfang immer mal wieder einen Bluescreen mit folgender Fehlermeldung Dpc...
WLAN Report: wo liegt das Problem?: Hallo, nach 3 Monate problemlosen Betriebs erhalte ich (nur) über mein HP-Notebook (über Router und Handy-HotSpot) den WLAN-Fehler: Disconnect...
Batterie wird nicht mehr erkannt: Hi! Vorgestern ist mir aufgefallen dass mein Surface Pro / WIndows 10 keine Akkulaufzeit mehr anzeigt in der Taskleiste. Habe dann alles...
BoD (DPC_WATCHDOG_VIOLATION / VIDEO_TDR_FAILURE) due to graphics driver or faulty hardware?: Since quite some time I regularly get BoDs with a DPC_WATCHDOG_VIOLATION (133) and after some driver changes VIDEO_TDR_FAILURE (116)...
WLAN Verbindung wird ständig neu aufgebaut: Hallo, ich habe einen relativen neuen PC mit einem Asus Mainboard, Modell ROG STRIX Z370-I GAMING. Dieser beinhaltet einen Realtek 8822BE...
