Ports überwachen
Diskutiere Ports überwachen im Windows Server 2003 Forum im Bereich Server Systeme; Hallo ich suche ein Programm das einzelne Ports überwacht Also wie viel traffic von dem Port aus/ein geht und welche ips sich versuchen zu...
Y
yogi
Also wie viel traffic von dem Port aus/ein geht und welche ips sich versuchen zu verbinden.
Am beste wäre ein Freeware Lösung :)
^L^
^L^
62
in-meiner-welt.at
05/04/2004  New utility: CurrPorts v1.00 (34kb) Copyright © 2004 Nir Sofer
http://members.lycos.co.uk/nirsoft1/utils/cports.gif
Description
CurrPorts displays the list of all currently opened TCP/IP and UDP ports on your local computer. For each port in the list, information about the process that opened the port is also displayed, including the process name, full path of the process, version information of the process (product name, file description, and so on), the time that the process was created, and the user that created it.
In addition, CurrPorts allows you to close unwanted TCP connections, kill the process that opened the ports, and save the TCP/UDP ports information to HTML file , XML file, or to tab-delimited text file.
CurrPorts also automatically mark with pink color suspicious TCP/UDP ports owned by unidentified applications (Applications without version information and icons)
System Requirements
This utility works perfectly under Windows 2000 and Windows XP. You can also use this utility on previous versions of Windows (Windows 98/ME), but in these versions of Windows, the process information for each port won't be displayed.
http://members.lycos.co.uk/nirsoft1/utils/cports.html
PS:
Ist eine Lieblingsseite von mir, hat's viele smarte Tools,
alle Standalone und genial klein.
If you have an idea for a useful utility that you can't find anywhere else,
you can contact NirSoft, and tell me about your idea.  :hehe
salü
Y
yogi
danke für die antworten werd das ma durchgehn ...
Ports überwachen
Ports überwachen - Ähnliche Themen
  • Baud-Rate für COM-Port
    Baud-Rate für COM-Port: Hallo, ich möchte eine Maschine über RS-232 mit meinem PC verbinden. Diese läuft mit einer festen Baud-Rate von 28800, allerdings kann ich...
  • Windows erkennt ethernet Port nicht mehr
    Windows erkennt ethernet Port nicht mehr: Hallo zusammen, seit gut 3 Wochen habe ich das Problem, dass mein Pc den Ethernetport nicht mehr erkennt. Er taucht zwar im Gerätemanager auf und...
  • Auf Windows PCs oder Tablets den Blizzard Klassiker Diablo spielen - So geht es per Browser Port
    Auf Windows PCs oder Tablets den Blizzard Klassiker Diablo spielen - So geht es per Browser Port: Der Hack&Slay RPG Klassiker Diablo von Blizzard ist nach wie vor sehr beliebt und kann nach wie vor auch gekauft werden. Wer aber die Original CD...
  • USB Ports funktionieren nur teilweise
    USB Ports funktionieren nur teilweise: Hallo, folgendes Problem seit einigen Tagen funktionieren manche meiner USB Anschlüsse nicht mehr...im BIOS funktioniert jedoch noch alles...
  • USB-Ports an Surface Dock funktionieren nicht
    USB-Ports an Surface Dock funktionieren nicht: Surface Pro 6 + Microsoft Dock Ich habe seit 1 Woche ein neues Surface + Docking Station. Sobald ich mein Surface an das Dock anschliesse sind...
