No video output via USB C Hub on Surface Laptop 3
Diskutiere No video output via USB C Hub on Surface Laptop 3 im Surface Book / Pro Forum im Bereich Microsoft Community; Hi, I am using a surface laptop 3 together with an Anker USB C Hub. One week ago I ordered an extenal display (HP24 fw). When it arrived I...
When it arrived I was able to connect the display via HDMI to the USB C Hub tand the the USB C Hub to the Surface.
I was able to extend my screen with this set up to the external display and could work on two displays at the same time.
Today I wanted to connect the surface to the display again but it stoppet working from one day to the other.
The strange thing is that I can see the second display in the display settings - but when I click on it the system says it can't recognize the other display.
There were no updates installed between the last time I used the complete set up and I also didn't changed anything else apart from reconnecting the USB C Hub.
I already tried lots of things to get it back to work but nothing worked so far.
I updated the intel drivers, the display driver, the processor driver, I cleared the graphics / video cache, I reset the Laptop,
I tested the USBC Hub together with the HP display on a lenovo think pad running windows 10 and it works just fine. No problems there.
I only have the problem with my Surface.
The next thing I tried was to connect the surface via the USBC Hub to my TV Screen. But that doesn't work either.
As I was able to confirm that the USB C Hub and the display works on another laptop + the surface also can't connect to a different display I am pretty sure that the problem must be the surface laptop 3 itself.
Has anyone had the same issues?
Any ideas how to fix this?
Thank you in advance!
Dave
No video output via USB C Hub on Surface Laptop 3 - Ähnliche Themen
  • Surface 7 pro - Video von Youtube auf TV - Bild verzerrt?
    Surface 7 pro - Video von Youtube auf TV - Bild verzerrt?: kleine Frage an die Wissenden ... wenn ich ein Youtube-Video per "verbinden mit drahtloser Anzeige" auf meinen 16:9 TV streame, dann wird der...
  • VLC Media Player Kurztipp - Ausschnitt aus Video abspeichern, z.B. um animiertes GIF zu erzeugen
    VLC Media Player Kurztipp - Ausschnitt aus Video abspeichern, z.B. um animiertes GIF zu erzeugen: Der VLC Media Player kann deutlich mehr als nur Videos abspielen. Wer sich zum Beispiel gern selbst ein persönliches GIF erstellen will, der kann...
  • MKV Video Dateien sind über Windows 10, App TV&Filme nicht mehr abspielbar
    MKV Video Dateien sind über Windows 10, App TV&Filme nicht mehr abspielbar: Hallo, ich habe im Videos Ordner Videos gespeichert im MKV Format, die ich aufgenommen habe. Diese waren bis vorgestern noch ohne Probleme über...
  • video scheduler internal error blue screen error
    video scheduler internal error blue screen error: Ich bekomme diese Meldung, va. wenn ich Skype nutze. Alle updates runtergeladen. Blue screen error: Video scheduler internal error. Hat jemand...
