Left 4 Dead - Weiterer Patch erschienen
Diskutiere Left 4 Dead - Weiterer Patch erschienen im Games-News Forum im Bereich News; Hallo Auf diejenigen unter euch die Left 4 Dead zocken, wartet beim Starten des Spieles ein neuer Patch. Der Patch bezieht sich Hauptsachlich...
Pvt.Caparzo
Pvt.Caparzo
47
Hell's Highway
Hallo
Auf diejenigen unter euch die Left 4 Dead zocken, wartet beim Starten des Spieles ein neuer Patch. Der Patch bezieht sich Hauptsachlich auf den Versus-Mode, hier haben die Klassen Tank, Smoker und Witch eine Überarbeitung erfahren! Natürlich wurden auch andere Kleinigkeiten gefixt, wie ihr im Anschluß sehen könnt:
Versus Mode Changes
- Tank melee attack can now hit multiple Survivors in one swing
- Fixed Tank punch being able to hit targets behind walls
- Fixes to \\\'Tank parking\\\'. The Tank will now run back and attack the Survivors if he becomes AI due to two players expiring the frustration meter
- Fixed a case where a Tank frustration meter could run out right as he was in his death animation and he would come back to life
- Fixed a case where the Tank was moving too slowly while crouching and being shot
- Tanks now have the possibility of spawning in a slightly different position for the first and second teams
- The order that the teams play as Survivors is now determined by which team has the higher overall score. The winning team will play as Survivors first
- The Smoker tongue can now target and grab victims through common infected
- Increased the cone in which a Smoker can grab a target
- The Witch no longer cuts Smoker tongues in a radius around her
- Boomers that explode in mid-air will now hit Survivors directly below them with Bile
- Reduced the damage that burning Hunters do to pounced victims
- Adjusted the time at which players take over from bots to avoid 5 seconds of the bot standing idle while the player finishes connecting.
- Fixed some cases where versus score was not being recalculated properly. It is no longer beneficial to pass pills between players at the end of the round or heal other players and then shoot them
- Fixed a case where it was possible to spectate an AI infected and hit +use to take them over
Server Changes
- Added convar sv_gametype that allows server operators to limit the types of games that will start on their server. Default value is \\\'coop,versus\\\'. Can be changed to just \\\'coop\\\' or just \\\'versus\\\' to limit to those game types
General changes
- Fixed a case where players would join as a dead Survivor when a living Survivor was still available
- Fixed a case where restarting a level due to the team dying would give more than the max primary ammo on restart
- Fixed the speaking icon showing up on the local player during level transition if voice_vox was set to 1
- The scoreboard now shows the numeric value of a player\\\'s ping
Game UI
- Quick match will now try to match to any campaign. Removed the preference to match to games according to the player progressing through all campaigns
- Games in a finale are now joinable via the Friends and Steam Group games list
Powered by: Shooterplanet.ch
Left 4 Dead - Weiterer Patch erschienen - Ähnliche Themen
iPhone to PC photo transfer via USB stops after seconds: Hi there, I have a brand new, clean install Windows 10 64bit PC and an iPhone. When I connect the phone to the PC, after some seconds I see the...
Disk Space not freed after uninstalling a game on xbox app on windows.: Hello, i uninstalled the game Final Fantasy 15 via xbox app on windows, but the 80+GB disk space were not being freed. I looked in the...
Movie Maker: Hello, Unfortunately, I do have a problem with a Microsoft movie maker file. I know Microsoft doesn’t support the program anymore but I‘ve used...
Surface Pro 4 can't find Windows: Hello everyone, i have problems with my Surface Pro 4. I use Onenote a lot and till now it worked fine, but since a week the Surface crashed...
Network Adapter Driver: Since I upgraded to Windows 10, I had some issues with audio and video so i used LatencyMon, which told me i have problems with the Network...
