Hilfe, weiß jemand, was relevantknowledge ist?
Diskutiere Hilfe, weiß jemand, was relevantknowledge ist? im Security / Firewall / Virenabwehr Forum im Bereich Software Forum; Hi Leute. Meine Firewall fragt seit kurzem nach einem Programm namens RelevantKnowledge. Weder bin ich der Meinung dies installiert zu haben, noch...
Deebee
39
Hi Leute.
Weder bin ich der Meinung dies installiert zu haben, noch finde ich was aussagekräftiges darüber.
Weiß einer von euch, was das ist?
THX4help!!!
Deebee
Herr Usedom
Herr Usedom
WinBoard
65
Oldenburg (Oldb.)
Rate Dir mal ein hijackthis log zu erstellen.
Besser ist das.:blush
i7-6700HQ
Outdoor oder vorm Rechner
Hier ist alles
http://www.file.net/prozess/rlls.dll.html
und eine leider englische Anleitung zur Entfernung desselben
RelevantKnowledge Description
RelevantKnowledge is an online market research service that conducts surveys on topics of interest to the Internet community. Responses to these surveys are aggregated and the results help determine the content you see when you surf. RelevantKnowledge monitors your Internet surfing, by routing your Internet activities through their service and logging information about the web pages that you visit and the actions that you take, such as the purchases and transactions you make. RelevantKnowledge can only monitor the Internet behavior and activity of your configured computers.
www.RelevantKnowledge.com
RelevantKnowledge Removal Instructions
Before you can delete files, you must first stop all the RelevantKnowledge processes that are running in memory.
Do this by ending all processes from the Task Manager.
Press CTRL+ALT+DELETE to open the Windows Task Manager. If you see multiple
"tabs," click on the "Processes" tab. For each process that you would like
to kill, find the process name in the list, click it to select it, and click
the "End Process" button.
Delete registry values Instructions:
Open the Windows Registry Editor by clicking on the Windows "Start" button,
clicking "Run," and typing "regedit" into the box in the Window that appears. Click "OK".
Once the Registry Editor is open, navigate through the registry tree to the
location of the key that you wish to delete. When you find the key or
value to be deleted, click on it to highlight it and press the "DELETE" key.
Unregister DLL Instructions:
To un-register a DLL file, first locate the file on your hard drive.
Open a command prompt window by clicking on the Windows "Start" button,
clicking "Run," and typing "cmd" into the box in the Window that appears. Click "OK."
Next type "regsvr32 /u " and press the "ENTER" key.
For example, to un-register a file called "myDll.dll" which is located in
the "C:\windows\system32" folder, your would type
"regsvr32 /u C:\windows\system32\myDll.dll" and press the "ENTER" key.
i7-6700HQ
Was ist das eigentlich jetzt genau für ein Tool?
Ein Monitoring-Tool, welches den Internetverkehr des eigenen LAN mitschreibt und auswertet.
Typische Adware oder Malware (Bezeichnung eigentlich egal) welche User-profile erstellt und Surfgewohnheiten verfolgt. Wer weiß was sonst noch.
K
KS_2007
Danke MikeK. Jetzt weiß ich dank deiner Hilfe was das für ein Tool ist. Es ist bestimmt von MS.
Hilfe, weiß jemand, was relevantknowledge ist? - Ähnliche Themen
Kann mir jemand helfen: Hallo Liebe, Leute ich wollte fragen ob mir jemand bei meinem meinem neusten threat weiter hilfen kann, natürlich weiß ich das ich viele user dazu...
Folder Lock Probleme: Hi liebes Forum, ich hoffe das jemand von euch mir helfen kann. Ich benutze Folder Lock seit etwas längerer Zeit und bisher hat es super...
Kein Zugriff auf FP und externes Laufwerk mitdem Backup: Hallo, ich bins mal wieder. Bisher konnte ich meine Probleme mit Hilfe von hier immer wieder lösen. Jetzt hoffe ich wieder. Also: Auf der FP ist...
GELÖST HILFE PLATTENCRASH: Hilfe, mir sind 2 Festplatten abgeschiert jetzt möchte ich die Partitionen wiederherstellen. Ich habe schon mal mit ein oder 2 Programmen...
Möglichkeiten um Remote die Hello PIN einzugeben: Hallo zusammen, kurze Frage, weiß jemand ob es möglich ist den PIN vom PC Remote einzugeben. Hatte das große Glück, dass Windows Hello meine PC...
relevant knowledge woher
