Garantieablauf - Akkuprobleme und Updateprobleme
Diskutiere Garantieablauf - Akkuprobleme und Updateprobleme im Surface Book / Pro Forum im Bereich Microsoft Community; Hello, I'm a lecturer on a fee basis (Academy for Banks for over 18 years) and until the beginning of March 2019 I was absolutely thrilled with...
Hello, I'm a lecturer on a fee basis (Academy for Banks for over 18 years) and until the beginning of March 2019 I was absolutely thrilled with the Surface Book. Especially in the seminar, the device was used (privately by me) and because of my enthusiasm also made advertising. Unfortunately, this enthusiasm has changed and after a long hesitation I have to write now. I have how many, the 2 rechargeable battery is no longer loaded. (tried everything - the connection points cleaned / new and of course tested by Microsoft charging station / plug and more since March 2019 after the warranty has expired.) Then I also noticed that certain updates were not run / installed and also here (I am not a specialist) I've reset the Surface Book and reinstalled everything according to her instructions I can not understand ---- If there are these problems with the battery / update etc. why is there no alternative eg new purchase for you and for the old device a "good / appropriate". Something like this has never happened to me that my enthusiasm from a techn. Device was so disappointed and wants to turn negative. ---- If there are these problems with the battery / update etc. why is there no alternative eg new purchase for you and for the old device a "good / appropriate". Something like this has never happened to me that my enthusiasm from a techn. Device was so disappointed and wants to turn negative.
Again I'm not a specialist for your programs and have always run all updates - I also have a subscription to the programs, because I expect more support. Maybe you check out, the idea with the exchange at the new purchase so that the complaints in the Internet can be solved harmoniously. My problem does not seem to be an isolated case. Thanks!
Garantieablauf - Akkuprobleme und Updateprobleme - Ähnliche Themen
Surface Pro 4 can't find Windows: Hello everyone, i have problems with my Surface Pro 4. I use Onenote a lot and till now it worked fine, but since a week the Surface crashed...
Surface Keyboard - How can I connect it at startup so I can use it in BIOS and other OS (without reconnecting it in Windows again): Hello! I have the microsoft surface ergonomic keyboard. I'd like to use it in Ubuntu and Windows at the same time without messing with the...
Display problems Surface Laptop first generation for the second time!: Dear Sirs and Madams, I purchased a Microsoft Laptop for the first time back in 2018. At some point the display randomly started to open pages...
surface 7 pro-after 30 seconds type-cover goes into standby: Hi all, I need help! I bought a new Surface Pro 7 with a type cover. But if I don't use the type-cover for around 30 seconds, it doesn't...
Surface Pro 4 can't find Windows / Surface findet Windows nicht: Hallo zusammen, da die Website auf der ich vorher war, auf Englisch war, habe ich meine Frage zunächst auf Englisch geschrieben. Jetzt wo hier...
