toastbrot
- Dabei seit
- 13.04.2005
- Beiträge
- 240
- Alter
- 40
ich versuche gerade über diese Beschreibung einen Webserver auf die Fritzbox zu installieren.
Folgendes ist bislang erfolgt:
- Apache wurde auf dem USB Stick hinterlegt
- unter /apache/conf wurde die httpd.conf angepasst
- Portforwarding in der Fritzbox wurde eingestellt
Wenn ich nun mittels #96*7* telnet öffne und den Befehl:
/var/media/ftp/Sony-StorageMedia-01/apache/httpd -f /var/media/ftp/Sony-StorageMedia-01/apache/conf/httpd.conf eingebe bekomme ich die Meldung "segemntation fault"
Wo mache ich den Fehler oder geht das mit meiner Fritzbox nicht ??
Info´s zu FritzBox:
FRITZ!Box Fon WLAN 7270 v3
Firmware-Version 74.04.88
Toast
Anbei noch die httpd.conf vom USB-Stick
Info´s zu FritzBox:
Toast
Code:
# Based upon the NCSA server configuration files originally by Rob McCool.
# This is the main Apache server configuration file. It contains the
# configuration directives that give the server its instructions.
# See <URL:http://httpd.apache.org/docs/> for detailed information about
# the directives.
# Do NOT simply read the instructions in here without understanding
# what they do. They're here only as hints or reminders. If you are unsure
# consult the online docs. You have been warned.
# After this file is processed, the server will look for and process
# sys:/apache/conf/srm.conf and then sys:/apache/conf/access.conf
# unless you have overridden these with ResourceConfig and/or
# AccessConfig directives here.
# The configuration directives are grouped into three basic sections:
# 1. Directives that control the operation of the Apache server process as a
# whole (the 'global environment').
# 2. Directives that define the parameters of the 'main' or 'default' server,
# which responds to requests that aren't handled by a virtual host.
# These directives also provide default values for the settings
# of all virtual hosts.
# 3. Settings for virtual hosts, which allow Web requests to be sent to
# different IP addresses or hostnames and have them handled by the
# same Apache server process.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32 and
# sys:/ for NetWare), the server will use that explicit path. If the
# filenames do *not* begin with "/", the value of ServerRoot is prepended
# -- so "logs/foo.log" with ServerRoot set to "/usr/local/apache" will be
# interpreted by the server as "/usr/local/apache/logs/foo.log".
### Section 1: Global Environment
# The directives in this section affect the overall operation of Apache,
# such as the number of concurrent requests it can handle or where it
# can find its configuration files.
# ServerType is either inetd, or standalone. Inetd mode is only supported on
# Unix platforms.
ServerType standalone
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the LockFile documentation
# (available at <URL:http://www.apache.org/docs/mod/core.html#lockfile>);
# you will save yourself a lot of trouble.
ServerRoot "/var/media/ftp/Sony-StorageMedia-01/apache"
user anonymous
group root
# PidFile: The file in which the server should record its process
# identification number when it starts.
PidFile /var/media/ftp/Sony-StorageMedia-01/apache/logs/httpd.pid
# ScoreBoardFile: File used to store internal server process information.
# Not all architectures require this. But if yours does (you'll know because
# this file will be created when you run Apache) then you *must* ensure that
# no two invocations of Apache share the same scoreboard file.
ScoreBoardFile /var/media/ftp/Sony-StorageMedia-01/apache/logs/apache_status
# In the standard configuration, the server will process this file,
# srm.conf, and access.conf in that order. The latter two files are
# now distributed empty, as it is recommended that all directives
# be kept in a single file for simplicity. The commented-out values
# below are the built-in defaults. You can have the server ignore
# these files altogether by using "/dev/null" (for Unix) or
# "nul" (for Win32) for the arguments to the directives.
#ResourceConfig conf/srm.conf
#AccessConfig conf/access.conf
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 15
# Number of concurrent threads (i.e., requests) the server will allow.
# Set this value according to the responsiveness of the server (more
# requests active at once means they're all handled more slowly) and
# the amount of system resources you'll allow the server to consume.
ThreadsPerChild 50
# When NetWare creates a thread you need to specify the stack size.
# You may need to increase this if you get stack overflows.
# ThreadStackSize 65536
#ThreadStackSize 65536
# MaxRequestsPerChild: the number of requests each child process is
# allowed to process before the child dies. The child will exit so
# as to avoid problems after prolonged use when Apache (and maybe the
# libraries it uses) leak memory or other resources. On most systems, this
# isn't really needed, but a few (such as Solaris) do have notable leaks
# in the libraries. For these platforms, set to something like 10000
# or so; a setting of 0 means unlimited.
# NOTE: This value does not include keepalive requests after the initial
# request per connection. For example, if a child process handles
# an initial request and 10 subsequent "keptalive" requests, it
# would only count as 1 request towards this limit.
MaxRequestsPerChild 0
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, instead of the default. See also the <VirtualHost>
# directive.
#Listen 3000
#Listen 12.34.56.78:80
Port 85
Listen 192.168.178.15:85
# BindAddress: You can support virtual hosts with this option. This directive
# is used to tell the server which IP address to listen to. It can either
# contain "*", an IP address, or a fully qualified Internet domain name.
# See also the <VirtualHost> and Listen directives.
#BindAddress *
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Please read the file http://httpd.apache.org/docs/dso.html for more
# details about the DSO mechanism and run `httpd -l' for the list of already
# built-in (statically linked and thus always available) modules in your httpd
# binary.
# Note: The order is which modules are loaded is important. Don't change
# the order below without expert advice.
# LoadModule anon_auth_module modules/authanon.nlm
# LoadModule cern_meta_module modules/cernmeta.nlm
# LoadModule digest_module modules/digest.nlm
# LoadModule expires_module modules/expires.nlm
# LoadModule log_forensic_module modules/forensic.nlm
# LoadModule headers_module modules/headers.nlm
# LoadModule proxy_module modules/proxy.nlm
# LoadModule rewrite_module modules/rewrite.nlm
# LoadModule speling_module modules/speling.nlm
# LoadModule status_module modules/status.nlm
# LoadModule info_module modules/info.nlm
# LoadModule unique_id_module modules/uniqueid.nlm
# LoadModule usertrack_module modules/usrtrack.nlm
# LoadModule tls_module modules/mod_tls.nlm
# LoadModule vhost_alias_module modules/vhost.nlm
# ExtendedStatus controls whether Apache will generate "full" status
# information (ExtendedStatus On) or just basic information (ExtendedStatus
# Off) when the "server-status" handler is called. The default is Off.
#ExtendedStatus On
### Section 2: 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition. These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# Port: The port to which the standalone server listens. For
# ports < 1023, you will need httpd to be run as root initially.
#Port 85
# ServerAdmin: Your address, where problems with the server should be
# e-mailed. This address appears on some server-generated pages, such
# as error documents.
ServerAdmin [email protected]
# ServerName allows you to set a host name which is sent back to clients for
# your server if it's different than the one the program would get (i.e., use
# "www" instead of the host's real name).
# Note: You cannot just invent host names and hope they work. The name you
# define here must be a valid DNS name for your host. If you don't understand
# this, ask your network administrator.
# If your host doesn't have a registered DNS name, enter its IP address here.
# You will have to access it by its address (e.g., http://123.45.67.89/)
# anyway, and this will make redirections work in a sensible way.
ServerName fritz.box
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
DocumentRoot "/var/media/ftp/Sony-StorageMedia-01/apache/htdocs"
# Each directory to which Apache has access, can be configured with respect
# to which services and features are allowed and/or disabled in that
# directory (and its subdirectories).
# First, we configure the "default" to be a very restrictive set of
# permissions.
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# This should be changed to whatever you set DocumentRoot to.
<Directory "/var/media/ftp/Sony-StorageMedia-01/apache/htdocs">
# This may also be "None", "All", or any combination of "Indexes",
# "Includes", "FollowSymLinks", "ExecCGI", or "MultiViews".
# Note that "MultiViews" must be named *explicitly* --- "Options All"
# doesn't give it to you.
Options Indexes FollowSymLinks MultiViews
# This controls which options the .htaccess files in directories can
# override. Can also be "All", or any combination of "Options", "FileInfo",
# "AuthConfig", and "Limit"
AllowOverride None
# Controls who can get stuff from this server.
# Order allow,deny
# Allow from all
</Directory>
# UserDir: The name of the directory which is appended onto a user's home
# directory if a ~user request is received.
<IfModule mod_userdir.c>
UserDir /home/*/public_html
</IfModule>
# Control access to UserDir directories. The following is an example
# for a site where these directories are restricted to read-only.
#<Directory /home/*/public_html>
# AllowOverride FileInfo AuthConfig Limit
# Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
# <Limit GET POST OPTIONS PROPFIND>
# Order allow,deny
# Allow from all
# </Limit>
# <LimitExcept GET POST OPTIONS PROPFIND>
# Order deny,allow
# Deny from all
# </LimitExcept>
#</Directory>
# DirectoryIndex: Name of the file or files to use as a pre-written HTML
# directory index. Separate multiple entries with spaces.
<IfModule mod_dir.c>
DirectoryIndex index.html
</IfModule>
# AccessFileName: The name of the file to look for in each directory
# for access control information.
AccessFileName .htaccess
# The following lines prevent .htaccess files from being viewed by
# Web clients. Since .htaccess files often contain authorization
# information, access is disallowed for security reasons. Comment
# these lines out if you want Web visitors to see the contents of
# .htaccess files. If you change the AccessFileName directive above,
# be sure to make the corresponding changes here.
# Also, folks tend to use names such as .htpasswd for password
# files, so this will protect those as well.
#<Files ~ "^\.ht">
# Order allow,deny
# Deny from all
# Satisfy All
#</Files>
# CacheNegotiatedDocs: By default, Apache sends "Pragma: no-cache" with each
# document that was negotiated on the basis of content. This asks proxy
# servers not to cache the document. Uncommenting the following line disables
# this behavior, and proxies will be allowed to cache the documents.
#CacheNegotiatedDocs
# UseCanonicalName: (new for 1.3) With this setting turned on, whenever
# Apache needs to construct a self-referencing URL (a URL that refers back
# to the server the response is coming from) it will use ServerName and
# Port to form a "canonical" name. With this setting off, Apache will
# use the hostname:port that the client supplied, when possible. This
# also affects SERVER_NAME and SERVER_PORT in CGI scripts.
UseCanonicalName On
# TypesConfig describes where the mime.types file (or equivalent) is
# to be found.
<IfModule mod_mime.c>
TypesConfig conf/mime.types
</IfModule>
# DefaultType is the default MIME type the server will use for a document
# if it cannot otherwise determine one, such as from filename extensions.
# If your server contains mostly text or HTML documents, "text/plain" is
# a good value. If most of your content is binary, such as applications
# or images, you may want to use "application/octet-stream" instead to
# keep browsers from trying to display binary files as though they are
# text.
DefaultType text/plain
# The mod_mime_magic module allows the server to use various hints from the
# contents of the file itself to determine its type. The MIMEMagicFile
# directive tells the module where the hint definitions are located.
# mod_mime_magic is not part of the default server (you have to add
# it yourself with a LoadModule [see the DSO paragraph in the 'Global
# Environment' section], or recompile the server and include mod_mime_magic
# as part of the configuration), so it's enclosed in an <IfModule> container.
# This means that the MIMEMagicFile directive will only be processed if the
# module is part of the server.
<IfModule mod_mime_magic.c>
MIMEMagicFile conf/magic
</IfModule>
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# LogRotateDaily: If set to 'on' log files rotate daily.
# LogRotateInterval n: If set, log files rotate after n minutes.
# The LogRotateDaily and LogRotateInterval directives are mutually
# exclusive. The rotated log file name adds the date suffix of
# YYYYMMDD to identify when the log was rotated.
# LogRotateDaily on
# LogRotateInterval 86400
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog /var/media/ftp/Sony-StorageMedia-01/apache/logs/error_log
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
#LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
#LogFormat "%h %l %u %t \"%r\" %>s %b" common
#LogFormat "%{Referer}i -> %U" referer
#LogFormat "%{User-agent}i" agent
# The location and format of the access logfile (Common Logfile Format).
# If you do not define any access logfiles within a <VirtualHost>
# container, they will be logged here. Contrariwise, if you *do*
# define per-<VirtualHost> access logfiles, transactions will be
# logged therein and *not* in this file.
#CustomLog /var/media/ftp/Sony-StorageMedia-01/apache/logs/access_log common
# If you would like to have agent and referer logfiles, uncomment the
# following directives.
#CustomLog logs/referer_log referer
#CustomLog logs/agent_log agent
# If you prefer a single logfile with access, agent, and referer information
# (Combined Logfile Format) you can use the following directive.
#CustomLog logs/access_log combined
# Optionally add a line containing the server version and virtual host
# name to server-generated pages (error documents, FTP directory listings,
# mod_status and mod_info output etc., but not CGI generated documents).
# Set to "EMail" to also include a mailto: link to the ServerAdmin.
# Set to one of: On | Off | EMail
ServerSignature On
# Aliases: Add here as many aliases as you need (with no limit). The format is
# Alias fakename realname
<IfModule mod_alias.c>
# Note that if you include a trailing / on fakename then the server will
# require it to be present in the URL. So "/icons" isn't aliased in this
# example, only "/icons/". If the fakename is slash-terminated, then the
# realname must also be slash terminated, and if the fakename omits the
# trailing slash, the realname must also omit it.
Alias /icons/ "/var/media/ftp/Sony-StorageMedia-01/apache/icons/"
<Directory "sys:/apache/icons">
Options Indexes MultiViews
AllowOverride None
# Order allow,deny
# Allow from all
</Directory>
# This Alias will project the on-line documentation tree under /manual/
# even if you change the DocumentRoot. Comment it if you don't want to
# provide access to the on-line documentation.
Alias /manual/ "/var/media/ftp/Sony-StorageMedia-01/apache/htdocs/manual/"
<Directory "/var/media/ftp/Sony-StorageMedia-01/apache/htdocs/manual">
Options Indexes FollowSymlinks MultiViews
AllowOverride None
# Order allow,deny
# Allow from all
</Directory>
# ScriptAlias: This controls which directories contain server scripts.
# ScriptAliases are essentially the same as Aliases, except that
# documents in the realname directory are treated as applications and
# run by the server when requested rather than as documents sent to the client.
# The same rules about trailing "/" apply to ScriptAlias directives as to
# Alias.
ScriptAlias /cgi-bin/ "/var/media/ftp/Sony-StorageMedia-01/apache/cgi-bin/"
# "sys:/apache/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
<Directory "/var/media/ftp/Sony-StorageMedia-01/apache/cgi-bin">
AllowOverride None
Options None
# Order allow,deny
# Allow from all
</Directory>
</IfModule>
# End of aliases.
# Redirect allows you to tell clients about documents which used to exist in
# your server's namespace, but do not anymore. This allows you to tell the
# clients where to look for the relocated document.
# Format: Redirect old-URI new-URL
# Directives controlling the display of server-generated directory listings.
<IfModule mod_autoindex.c>
# FancyIndexing is whether you want fancy directory indexing or standard
IndexOptions FancyIndexing
# AddIcon* directives tell the server which icon to show for different
# files or filename extensions. These are only displayed for
# FancyIndexed directories.
AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
AddIconByType (TXT,/icons/text.gif) text/*
AddIconByType (IMG,/icons/image2.gif) image/*
AddIconByType (SND,/icons/sound2.gif) audio/*
AddIconByType (VID,/icons/movie.gif) video/*
AddIcon /icons/binary.gif .bin .exe
AddIcon /icons/binhex.gif .hqx
AddIcon /icons/tar.gif .tar
AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
AddIcon /icons/a.gif .ps .ai .eps
AddIcon /icons/layout.gif .html .shtml .htm .pdf
AddIcon /icons/text.gif .txt
AddIcon /icons/c.gif .c
AddIcon /icons/p.gif .pl .py
AddIcon /icons/f.gif .for
AddIcon /icons/dvi.gif .dvi
AddIcon /icons/uuencoded.gif .uu
AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
AddIcon /icons/tex.gif .tex
AddIcon /icons/bomb.gif core
AddIcon /icons/back.gif ..
AddIcon /icons/hand.right.gif README
AddIcon /icons/folder.gif ^^DIRECTORY^^
AddIcon /icons/blank.gif ^^BLANKICON^^
# DefaultIcon is which icon to show for files which do not have an icon
# explicitly set.
DefaultIcon /icons/unknown.gif
# AddDescription allows you to place a short description after a file in
# server-generated indexes. These are only displayed for FancyIndexed
# directories.
# Format: AddDescription "description" filename
#AddDescription "GZIP compressed document" .gz
#AddDescription "tar archive" .tar
#AddDescription "GZIP compressed tar archive" .tgz
# ReadmeName is the name of the README file the server will look for by
# default, and append to directory listings.
# HeaderName is the name of a file which should be prepended to
# directory indexes.
ReadmeName README.html
HeaderName HEADER.html
# IndexIgnore is a set of filenames which directory indexing should ignore
# and not include in the listing. Shell-style wildcarding is permitted.
IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
</IfModule>
# End of indexing directives.
# Document types.
# AddType allows you to tweak mime.types without actually editing it, or to
# make certain files to be certain types.
AddType application/x-tar .tgz
# AddEncoding allows you to have certain browsers uncompress
# information on the fly. Note: Not all browsers support this.
# Despite the name similarity, the following Add* directives have nothing
# to do with the FancyIndexing customization directives above.
AddEncoding x-compress .Z
AddEncoding x-gzip .gz .tgz
# If the AddEncoding directives above are commented-out, then you
# probably should define those extensions to indicate media types:
#AddType application/x-compress .Z
#AddType application/x-gzip .gz .tgz
# AddLanguage allows you to specify the language of a document. You can
# then use content negotiation to give a browser a file in a language
# it can understand.
# Note 1: The suffix does not have to be the same as the language
# keyword --- those with documents in Polish (whose net-standard
# language code is pl) may wish to use "AddLanguage pl .po" to
# avoid the ambiguity with the common suffix for perl scripts.
# Note 2: The example entries below illustrate that in quite
# some cases the two character 'Language' abbreviation is not
# identical to the two character 'Country' code for its country,
# E.g. 'Danmark/dk' versus 'Danish/da'.
# Note 3: In the case of 'ltz' we violate the RFC by using a three char
# specifier. But there is 'work in progress' to fix this and get
# the reference data for rfc1766 cleaned up.
# Danish (da) - Dutch (nl) - English (en) - Estonian (ee)
# French (fr) - German (de) - Greek-Modern (el)
# Italian (it) - Korean (kr) - Norwegian (no) - Norwegian Nynorsk (nn)
# Portugese (pt) - Luxembourgeois* (ltz)
# Spanish (es) - Swedish (sv) - Catalan (ca) - Czech(cs)
# Polish (pl) - Brazilian Portuguese (pt-br) - Japanese (ja)
# Russian (ru)
AddLanguage da .dk
AddLanguage nl .nl
AddLanguage en .en
AddLanguage et .ee
AddLanguage fr .fr
AddLanguage de .de
AddLanguage el .el
AddLanguage he .he
AddCharset ISO-8859-8 .iso8859-8
AddLanguage it .it
AddLanguage ja .ja
AddCharset ISO-2022-JP .jis
AddLanguage kr .kr
AddCharset ISO-2022-KR .iso-kr
AddLanguage nn .nn
AddLanguage no .no
AddLanguage pl .po
AddCharset ISO-8859-2 .iso-pl
AddLanguage pt .pt
AddLanguage pt-br .pt-br
AddLanguage ltz .lu
AddLanguage ca .ca
AddLanguage es .es
AddLanguage sv .sv
AddLanguage cs .cz .cs
AddLanguage ru .ru
AddLanguage zh-TW .zh-tw
AddCharset Big5 .Big5 .big5
AddCharset WINDOWS-1251 .cp-1251
AddCharset CP866 .cp866
AddCharset ISO-8859-5 .iso-ru
AddCharset KOI8-R .koi8-r
AddCharset UCS-2 .ucs2
AddCharset UCS-4 .ucs4
AddCharset UTF-8 .utf8
# LanguagePriority allows you to give precedence to some languages
# in case of a tie during content negotiation.
# Just list the languages in decreasing order of preference. We have
# more or less alphabetized them here. You probably want to change this.
<IfModule mod_negotiation.c>
LanguagePriority en da nl et fr de el it ja kr no pl pt pt-br ru ltz ca es sv tw
</IfModule>
# AddHandler allows you to map certain file extensions to "handlers",
# actions unrelated to filetype. These can be either built into the server
# or added with the Action command (see below)
# If you want to use server side includes, or CGI outside
# ScriptAliased directories, uncomment the following lines.
# To use CGI scripts:
#AddHandler cgi-script .cgi
# To use server-parsed HTML files
#AddType text/html .shtml
#AddHandler server-parsed .shtml
# Uncomment the following line to enable Apache's send-asis HTTP file
# feature
#AddHandler send-as-is asis
# If you wish to use server-parsed imagemap files, use
#AddHandler imap-file map
# To enable type maps, you might want to use
#AddHandler type-map var
</IfModule>
# End of document types.
# Action lets you define media types that will execute a script whenever
# a matching file is called. This eliminates the need for repeated URL
# pathnames for oft-used CGI file processors.
# Format: Action media/type /cgi-script/location
# Format: Action handler-name /cgi-script/location
# MetaDir: specifies the name of the directory in which Apache can find
# meta information files. These files contain additional HTTP headers
# to include when sending the document
#MetaDir .web
# MetaSuffix: specifies the file name suffix for the file containing the
# meta information.
#MetaSuffix .meta
# Customizable error response (Apache style)
# these come in three flavors
# 1) plain text
#ErrorDocument 500 "The server made a boo boo.
# n.b. the (") marks it as text, it does not get output
# 2) local redirects
#ErrorDocument 404 /missing.html
# to redirect to local URL /missing.html
#ErrorDocument 404 /cgi-bin/missing_handler.pl
# N.B.: You can redirect to a script or a document using server-side-includes.
# 3) external redirects
#ErrorDocument 402 http://www.example.com/subscription_info.html
# N.B.: Many of the environment variables associated with the original
# request will *not* be available to such a script.
# Customize behaviour based on the browser
<IfModule mod_setenvif.c>
# The following directives modify normal HTTP response behavior.
# The first directive disables keepalive for Netscape 2.x and browsers that
# spoof it. There are known problems with these browser implementations.
# The second directive is for Microsoft Internet Explorer 4.0b2
# which has a broken HTTP/1.1 implementation and does not properly
# support keepalive when it is used on 301 or 302 (redirect) responses.
BrowserMatch "Mozilla/2" nokeepalive
BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
# The following directive disables HTTP/1.1 responses to browsers which
# are in violation of the HTTP/1.0 spec by not being able to grok a
# basic 1.1 response.
BrowserMatch "RealPlayer 4\.0" force-response-1.0
BrowserMatch "Java/1\.0" force-response-1.0
BrowserMatch "JDK/1\.0" force-response-1.0
</IfModule>
# Allow server status reports, with the URL of http://servername/server-status
# Change the ".example.com" to match your domain to enable.
<IfModule mod_status.c>
<Location /server-status>
SetHandler server-status
# Order deny,allow
# Deny from all
# Allow from .example.com
</Location>
</IfModule>
# Allow remote server configuration reports, with the URL of
# http://servername/server-info (requires that mod_info.c be loaded).
<IfModule mod_info.c>
<Location /server-info>
SetHandler server-info
Order deny,allow
Deny from all
</Location>
</IfModule>
# There have been reports of people trying to abuse an old bug from pre-1.1
# days. This bug involved a CGI script distributed as a part of Apache.
# By uncommenting these lines you can redirect these attacks to a logging
# script on phf.apache.org. Or, you can record them yourself, using the script
# support/phf_abuse_log.cgi.
#<Location /cgi-bin/phf*>
# Deny from all
# ErrorDocument 403 http://phf.apache.org/phf_abuse_log.cgi
#</Location>
### Section 3: Virtual Hosts
# VirtualHost: If you want to maintain multiple domains/hostnames on your
# machine you can setup VirtualHost containers for them.
# Please see the documentation at <URL:http://www.apache.org/docs/vhosts/>
# for further details before you try to setup virtual hosts.
# You may use the command line option '-S' to verify your virtual host
# configuration.
# If you want to use name-based virtual hosts you need to define at
# least one IP address (and port number) for them.
#NameVirtualHost 12.34.56.78:80
# VirtualHost example:
# Almost any Apache directive may go into a VirtualHost container.
#<VirtualHost ip.address.of.host.example.com>
# ServerAdmin [email protected]
# DocumentRoot /www/docs/host.example.com
# ServerName host.example.com
# ErrorLog logs/host.example.com-error_log
# CustomLog logs/host.example.com-access_log common
#</VirtualHost>
#<VirtualHost _default_:*>
#</VirtualHost>
# SecureListen is the same as the Listen directive only it
# ensures the port will be secure. The second parameter
# specifies the certificate to use. "SSL CertificateIP" is
# the default.
<IfModule mod_tls.c>
SecureListen 443 "SSL CertificateIP"
</IfModule>
