freeswan gateway kann keine remote machine pingen
Diskutiere freeswan gateway kann keine remote machine pingen im Linux Forum im Bereich Weitere Betriebssysteme; hallo habe ernstahftes problem mit freeswan gateway ( linux SuSE 8.2 ) , verbunden via ipsec tunnel mit Watchguard firewall. Auf dem linux...
cccc
hallo
Auf dem linux gateway habe 2 interfaces :
eth0 (externes) mit einer Internet adresse (212.X.X.X) und
eth1 (internes) mit einer privater adresse (192.168.115.1)
mein ipsec.conf :
config setup
interfaces=%defaultroute
klipsdebug=none
plutodebug=none
plutoload=%search
plutostart=%search
uniqueids=yes
forwardcontrol=yes
conn %default
keyingtries=0
disablearrivalcheck=no
authby=secret
#compress=yes
#leftrsasigkey=%dnsondemand
#rightrsasigkey=%dnsondemand
conn roadwarrior
left=%any
conn me-to-anyone
#left=%defaultroute
#right=%opportunistic
#keylife=1h
#rekey=no
# for initiator only OE,
# after putting your key
#leftid=@myhostname.example.com
# uncomment this next line to enable it
# auto=route
conn Firebox1
left=195.X.X.X
leftnexthop=%defaultroute
leftsubnet=192.168.0.0/24
right=212.X.X.X
rightnexthop=%defaultroute
rightsubnet=192.168.115.0/24
leftupdown=/usr/lib/ipsec/_updown_custom
auto=start
Der tunnel funktioniert.
# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
212.X.X.X * 255.255.255.240 U 0 0 0 eth0
212.X.X.X * 255.255.255.240 U 0 0 0 ipsec0
192.168.0.0 gw.xxx.net 255.255.255.0 UG 0 0 0 ipsec0
192.168.115.0 * 255.255.255.0 U 0 0 0 eth1
default gw.xxx.net 0.0.0.0 UG 0 0 0 eth0
# ipsec verify
Checking your system to see if IPsec was installed and started correctly
Version check and ipsec on-path [OK]
Checking for KLIPS support in kernel [OK]
Checking for RSA private key (/etc/ipsec.secrets) [OK]
Checking that pluto is running [OK]
DNS checks.
Looking for forward key for ext [FAILED]
Looking for TXT in reverse map: X.X.X.212.in-addr.arpa [OK]
Does the machine have at least one non-private address [OK]
I kann von jeder remote maschine linux gateway anpingen,
aber NICHT umgekehrt !
auf der linux gateway seite läuft keine firewall.
auf der remote seite, sind alle ports "ANY to ANY" für linux erlaubt.
interessanterweise kann ich von jeder maschine hinter
dem linux gateway ( meine auf der gateway site ),
jede remote machine pingen, aber NICHT vom linux gateway direkt.
was ist da falsch ?
cccc
cccc
eigentlich, nix ist falsch:
mit
ping -I Locale_IP Remote_IP
funktioniert bestens.
freeswan gateway kann keine remote machine pingen - Ähnliche Themen
  • Kein Zugriff auf den Standard-Gateway meines Routers mehr
    Kein Zugriff auf den Standard-Gateway meines Routers mehr: Hallo zusammen, seit ein paar Monaten habe ich extreme Probleme mit Windows Defender. Ich kann mit Google Chrome nicht mehr auf meinen...
  • Wie erfahre ich meine IP-Adresse und Gateway
    Wie erfahre ich meine IP-Adresse und Gateway: Wie erfahre ich meine IP Adresse und Gateway
  • Windows 10 - 1809 VPN verbindet nicht korrekt (Gateway 0.0.0.0)
    Windows 10 - 1809 VPN verbindet nicht korrekt (Gateway 0.0.0.0): Moin, seit dem Update, funktioniert unser VPN Tool nicht mehr, welches automatisch eine VPN Verbindung überprüft und verbindet. Das ganze macht...
  • VPN Gateway/Router ?
    VPN Gateway/Router ?: Hallo, habe ein Problem mit meinem Internet Anbieter, da ich mit meiner Nintendo Switch nicht online spielen kann. Habe nun über ein RPi ein VPN...
  • probleme mit SuSEfirewall2 und freeswan
    probleme mit SuSEfirewall2 und freeswan: hallo habe mit meiner linux kiste SuSE 8.2 ein freeswan gateway erfolgreich eingerichtet. dort habe 2 interfaces: externes eth0 195.X.X.10 und...
