Fehlerprotokolle im System32 Ordner - z.B. default_error_stack-430099-000000.txt
Diskutiere Fehlerprotokolle im System32 Ordner - z.B. default_error_stack-430099-000000.txt im Windows 10 Forum im Bereich Microsoft Community; Im 3 Minuten Takt, werden im Ordner C:\Windows\System32 Fehlerprotokolle generiert: --------------------------------------- [ * Error Stack...
[ * Error Stack Dump BEGIN * ]
...Stack Protected Flag:...............[1].
...Stack Expandable Flag:..............[1].
...Stack Size Limited Flag:............[1]
...Stack Size Limit Size:..............[256].
...Stack Internal Error Flag:..........[0].
...Stack Max Entries:..................[16].
...Stack Entries Count:................[2].
...Stack Entries Address:..............[00000000012D89E0].
......ERROR ENTRY: [0]
.........User Interface Flag:..........[1].
.........Offending Item:...............[SYSTEM\CurrentControlSet\Services\ESRV_QUEENCREEK].
.........Proposed Solution:............[Please Check Your Start Key / Values Specifications.].
.........Reported Inline:..............[1].
.........Out Of Cycle Flag:............[1].
.........Thread ID:....................[13536].
.........Last System Error Code........[0x0].
.........Error Path:...................[APPLICATION PATH].
.........Error Severity:...............[UN-RECOVERABLE].
.........Untranslated Error Code:......[657].
.........Error Code:...................[657: A Root Or Key Start Dependency Has Not Been Met.].
.........Error Sample:.................[0].
.........Error Elapsed Time (in ms):...[0].
.........Error Time:...................[Wed Feb 19 07:28:51 2020].
.........Error File:...................[(...)\driver.c].
.........Error Line:...................[24883].
......ERROR ENTRY: [1]
.........Last System Error Code........[0xcb].
.........Error Severity:...............[RECOVERABLE].
.........Untranslated Error Code:......[598].
.........Error Code:...................[598: Unable To Open A Registry Key.].
.........Error Line:...................[24890].
[ * Error Stack Dump END * ]
"C:\Program Files\Intel\SUR\QUEENCREEK\esrv_svc.exe" "--START" "--depend_on_key" "SYSTEM\CurrentControlSet\Services\ESRV_QUEENCREEK" "--address" "127.0.0.1" "--port" "49350" "--time_in_ms" "--pause" "5000" "--watchdog" "5" "--watchdog_cpu_usage_limit" "50" "--end_on_error" "--priority_boost" "--kernel_priority_boost" "--shutdown_priority_boost" "--report_errors_inline" "--library" "C:\Program Files\Intel\SUR\QUEENCREEK\intel_modeler.dll" "--no_pl" "--device_options" " time=no generate_key_file=no performance=no in_cycle_performance=no output_format=sur output=w output_folder='C:\ProgramData\Intel\SUR\QUEENCREEK\IntelData' upload_folder='C:\ProgramData\Intel\SUR\QUEENCREEK\IntelData\UpldReports' limit_output_by=time output_limit=3600000 output_buffer=1024 output_cache=4096 lock_xls=yes os='C:\Program Files\Intel\SUR\QUEENCREEK\os_counters.txt' il='C:\Program Files\Intel\SUR\QUEENCREEK\acpi_battery_input.dll' il='C:\Program Files\Intel\SUR\QUEENCREEK\wifi_input.dll' il='C:\Program Files\Intel\SUR\QUEENCREEK\devices_use_input.dll','service=yes' il='C:\Program Files\Intel\SUR\QUEENCREEK\intel_system_power_state_input.dll' il='C:\Program Files\Intel\SUR\QUEENCREEK\intel_process_input.dll','C:\Program Files\Intel\SUR\QUEENCREEK\process_input_options.txt' il='C:\Program Files\Intel\SUR\QUEENCREEK\intel_winstat_input.dll' il='C:\Program Files\Intel\SUR\QUEENCREEK\intel_acdc_setting_input.dll' il='C:\Program Files\Intel\SUR\QUEENCREEK\sema_thermal_input.dll' il='C:\Program Files\Intel\SUR\QUEENCREEK\intel_quality_and_reliability_input.dll' il='C:\Program Files\Intel\SUR\QUEENCREEK\intel_sampler_input.dll' il='C:\Program Files\Intel\SUR\QUEENCREEK\intel_stress_odometer_input.dll' il='C:\Program Files\Intel\SUR\QUEENCREEK\intel_turbo_input.dll' "
Wie kann man das abstellen, bzw. wo liegt der Fehler?
Diese *.exe gibt es nicht mehr: C:\Program Files\Intel\SUR\QUEENCREEK\esrv_svc.exe und soll auch nichts mehr tun.
Es geht also primär darum, die Fehlermeldung zu unterbinden. Ich musste gerade 430.098 Textdateien manuell entfernen ;-(
Wer weiß was dazu?
Fehlerprotokolle im System32 Ordner - z.B. default_error_stack-430099-000000.txt - Ähnliche Themen
  • Fehlerprotokoll Verzeichnis (Ordner: MEMORY.DMP) nicht zu finden
    Fehlerprotokoll Verzeichnis (Ordner: MEMORY.DMP) nicht zu finden: Unter Systemsteuerung/Gerätemanager/Ereignisanzeigen werden verschiedene Störungen und Fehler verwaltet. Anlässlich einer abgebrochenen...
  • Fehlerprotokoll in Windows 10 suchen
    Fehlerprotokoll in Windows 10 suchen: Hallo zusammen, wo speichert Windows 10 (home Premium 64 bit Creators update) die Fehlerprotokolle, die von einer fehlerhaft laufenden...
  • C:\Windows\System32\mfplat.dll ist nit vorgesehen oder enhält einen fehler
    C:\Windows\System32\mfplat.dll ist nit vorgesehen oder enhält einen fehler: Guten Tag, Mein Problem liegt darin das ich nach guten ein Monat mal wieder mein PC startete , jedoch bekamm ich dann diese Fehlermeldung. Ich...
  • A critical system process, C:\Windows\system32\lsass.exe, failed with status code 1073741819
    A critical system process, C:\Windows\system32\lsass.exe, failed with status code 1073741819: Hi, since 05.07.2020 my Laptop HP Pavilion always reboots with the following message: Sometimes the user cant login and there is only the...
    real casino
    paradise casin3o
    jackpot poker
    casinos online
    , how to make a living playing poker, slots casinos, hippodrome casin)o, pAoker mira, harrahs casino joliet, harrahs caQsino joliet, sugarhouse casino poker, lake elsinore casino, real casFino, seminole hard rock poker, seminole hard rock pokeor, closest casino to me, world series poker, world series kpoker, gila river casino, gila river coasino, parx posker blog, teen patti indian poker
