Fehlermeldung beim SCRIPT
Diskutiere Fehlermeldung beim SCRIPT im Programmierung Forum im Bereich Software Forum; Hallo, hab im Anhang ein screenshot, wenn ich mein Script aufrufe bekomme ich diese Fehlermeldung, weis wer wie ich das umgehe??!?!?! DANKE
danijelhr
DANKE
HWFlo
32
Hilfreich wäre es dein Skript mal zu sehen bzw. en Bereich um die in der Meldung angegebene Zeile.
danijelhr
'Returns the primary group of a user
function getPrimaryGroup (DomainName, UserLoginName)
dim oUsr
dim oGrp
' Bind to the user object with the Windows NT provider.
set oUsr = GetObject("WinNT://" & DomainName & "/" & UserLoginName & ",user")
set grp = oUsr.Groups
GrpID = oUsr.PrimaryGroupID
GrpName = ""
' Building Query Filter for the search for all the groups that the user is a member of.
QueryFilter = "(|"
for each Item in Grp
NT4Name = replace(Item.ADsPath,"WinNT://","")
tempArray = split(nt4Name,"/")
NT4Name = tempArray(1)
QueryFilter = QueryFilter & "(samAccountName=" & NT4Name & ")"
next
QueryFilter = QueryFilter & ")"
' Building LDAP dialect Query String.
'QueryString = "<LDAP://" & DomainName & ">;" & QueryFilter & ";PrimaryGroupToken,distinguishedName;subtree"
QueryString = "<LDAP://" & DomainName & ">;" & QueryFilter & ";PrimaryGroupToken,Name;subtree"
' Performing Query against the Active Directory for all the groups that
' the user belongs to and retrieving the RID of the group object off
' the PrimaryGroupToken attribute on the user.
Dim oConnection, oCommand, oRecordset
Set oConnection = CreateObject("ADODB.Connection")
Set oCommand = CreateObject("ADODB.Command")
oConnection.Provider = "ADsDSOObject"
oConnection.Open "Active Directory Provider"
Set oCommand.ActiveConnection = oConnection
oCommand.CommandText = QueryString
oCommand.Properties("Page Size") = 900
Set oRecordset = oCommand.Execute '<--Fehler passiert genau hier
' Looping through all the records in the search result to determine whether
' any of these group's PrimaryGroupToken attribute value match the
' PrimaryGroupID attribute value stored on the user object.
While ((NOT oRecordset.EOF) and (Not bGroupFound))
if (GrpID = oRecordset.Fields("PrimaryGroupToken").value) then
GrpName = oRecordset.Fields("Name").Value
bGroupFound = True
End If
oRecordset.moveNext
Wend
Set oRecordset = Nothing
Set oCommand = Nothing
Set oConnection = Nothing
if (not bGroupFound) then
GrpName = "Primary Group Not Found"
end if
getPrimaryGroup = GrpName
end function
Fehlermeldung beim SCRIPT - Ähnliche Themen
  • Fehlermeldung beim Start von Excel 2010
    Fehlermeldung beim Start von Excel 2010: Diese Meldung erscheint ständig, wenn ich Excel 2010 unter Win 10 starte. Gibt es irgendwo ein ADMIN-Problem?
  • Outlook 365 - Fehlermeldung beim Internetkalender
    Outlook 365 - Fehlermeldung beim Internetkalender: mir wird ständig einer Fehlermeldung beim Internetkalendar angezeigt. Selbst wenn ich den Fehler reparieren lasse (und das habe ich sicher schon...
  • Fehlermeldung 0x8024a105 beim Update
    Fehlermeldung 0x8024a105 beim Update: Wie kann ich o.g Fehler beheben? Bitte genaue Tastenfolge bei der Eingabeaufforderung angeben.
  • Outlook 2010 Fehlermeldung : "Problem beim Herstellen der Verbindung mit dem Server"
    Outlook 2010 Fehlermeldung : "Problem beim Herstellen der Verbindung mit dem Server": Schönen guten Abend / Tag alle zusammen ! Ich wollte meinem Vater bezüglich Outlook 2010 helfen, bis her leider vergebens. Dieser hatte sich vor...
