falls jemand mehr über dieses board wissen willst zb. benchmarks dann auf diesen link klicken
Board - ansonsten technische details-
DFI LANPARTY Pro 875 - Page 2 [Specifications]
Specifications
CPU
Intel® Pentium® 4 Processor with Hyper-Threading Technology 800MHz and 533MHz FSB
Intel® Pentium® 4 Northwood Processor 533MHz and 400MHz FSB
Intel® Celeron® Northwood processor 400MHz system data bus
CHIPSET
Intel® 875P chipset
- Intel® 82875P Memory Controller Hub (MCH)
- Intel® 82801ER I/O Controller Hub (ICH5R)
SYSTEM MEMORY
Supports dual channel (128-bit wide) memory interface
- Each channel supports 2 DIMM sockets
Supports up to 4GB system memory
Supports Dynamic mode to optimize system performance
Synchronous operation with processor system bus
- PC2100/PC2700/PC3200 (DDR266/DDR333/DDR400) with 800MHz FSB CPU (supports PAT mode). DDR333 will run at 320MHz memory frequency when used with 800MHz FSB CPU.
- PC2100/PC2700 (DDR266/DDR333) with 533MHz FSB CPU
- PC2100 (DDR266) with 400MHz FSB CPU
Supports ECC/non-ECC DIMMs
Supports unbuffered DIMMs
BIOS
Award BIOS, Windows® 98SE/2000/ME/XP Plug and Play compatible
Genie BIOS provides:
- CPU/DRAM overclocking in 1MHz stepping
- AGP/PCI/SATA overclocking
- CPU/DIMM/AGP overvoltage
Flash EPROM for easy BIOS upgrades
4Mbit flash memory
HARDWARE MONITOR
Monitors CPU/system temperature and overheat alarm
Monitors CPU/1.5V/5VSB/VBAT/3.3V/5V/±12V voltages and failure alarm
Monitors CPU/chassis/second fan speed and failure alarm
Automatic chassis/second fans on/off control
Read back capability that displays temperature, voltage and fan speed
CPU Fan Protection function monitors the CPU fan during system boot-up
CPU Temperature Protection function monitors CPU temperature during system boot-up
AUDIO FEATURES
20-bit stereo full-duplex codec with independent variable sampling rate
High quality differential CD input
True stereo line level outputs
S/PDIF-in/out interface
6-channel audio output
ONBOARD CSA GIGABIT LAN
Uses 82547EI Gigabit LAN CSA interface
Integrated power management functions
Full duplex support at 10, 100 and 1000 Mbps
Supports IEEE 802.3u auto-negotiation
Supports wire for management
ATA RAID
Uses HighPoint 372N RAID controller
RAID 0, 1, 0+1 and 1.5
Two independent IDE channels support 4 hard disk drives (ATA/33, ATA/66, ATA/100, ATA/133 or EIDE)
Supports PIO modes 0/1/2/3/4, DMA modes 0/1/2 and UDMA modes 0/1/2/3/4/5/6
ICH5R SATA IDE/RAID0 INTERFACE
Supports two SATA (Serial ATA) interfaces which are compliant with SATA 1.0 specification (1.5Gbps interface)
Supports RAID 0
ACCELERATED GRAPHICS PORT (A.G.P.)
Supports 1.5V AGP 8x (2.13GB/sec.) and AGP 4x (1066MB/sec.) for 3D graphics applications (AGP 2x and 3.3V AGP card are not supported)
Supports AGP 3.0 and AGP 2.0 spec.
EXPANSION SLOTS
1 AGP slot
5 PCI slots
COMPATIBILITY
PCI 2.2 and AC ’97 compliant
Intel AGP version 3.0
PCB
4 layers, ATX form factor
30.5cm (12.05") x 24.4cm (9.6")
