BSOD SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
Diskutiere BSOD SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e) im Windows 10 Forum im Bereich Microsoft Community; SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e) This is a very common bugcheck. Usually the exception address pinpoints the driver/function that...
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8026b63a319, The address that the exception occurred at
Arg3: ffffec8a368c71a8, Exception Record Address
Arg4: ffffec8a368c69f0, Context Record Address
Debugging Details:
*** WARNING: Unable to verify checksum for win32k.sys
KEY_VALUES_STRING: 1
Key : AV.Fault
Value: Read
Key : Analysis.CPU.Sec
Value: 3
Key : Analysis.DebugAnalysisProvider.CPP
Value: Create: 8007007e on DESKTOP-DEQQ9CP
Key : Analysis.DebugData
Value: CreateObject
Key : Analysis.DebugModel
Value: CreateObject
Key : Analysis.Elapsed.Sec
Value: 27
Key : Analysis.Memory.CommitPeak.Mb
Value: 73
Key : Analysis.System
Value: CreateObject
ADDITIONAL_XML: 1
BUGCHECK_CODE: 7e
BUGCHECK_P1: ffffffffc0000005
BUGCHECK_P2: fffff8026b63a319
BUGCHECK_P3: ffffec8a368c71a8
BUGCHECK_P4: ffffec8a368c69f0
EXCEPTION_RECORD: ffffec8a368c71a8 --
(.exr 0xffffec8a368c71a8)
ExceptionAddress: fffff8026b63a319 (nt!FsRtlAcquireHeaderMutex+0x0000000000000039)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT: ffffec8a368c69f0 --
(.cxr 0xffffec8a368c69f0)
rax=0000000000000001 rbx=ffffc8879b18e360 rcx=ffffc8879b18e040
rdx=d05ca2f200109a00 rsi=0000000000000000 rdi=d05ca2f200109a00
rip=fffff8026b63a319 rsp=ffffec8a368c73e0 rbp=fffff8026de05450
r8=ffffec8a368c73f8 r9=7fffc887940b74b0 r10=fffff8026b63a2e0
r11=ffffec8a368c73e0 r12=0000000000000000 r13=0000000000000000
r14=ffffec8a368c7501 r15=ffffd90878143a40
iopl=0 nv up ei ng nz na pe nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00050282
nt!FsRtlAcquireHeaderMutex+0x39:
fffff802`6b63a319 f00fba3700 lock btr dword ptr [rdi],0 ds:002b:d05ca2f2`00109a00=????????
Resetting default scope
BLACKBOXBSD: 1 (
!blackboxbsd)
BLACKBOXNTFS: 1 (
!blackboxntfs)
BLACKBOXPNP: 1 (
!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
READ_ADDRESS: fffff8026bb733b8: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
fffff8026ba2a3c8: Unable to get Flags value from nt!KdVersionBlock
unable to get nt!MmSpecialPagesInUse
ffffffffffffffff
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
EXCEPTION_STR: 0xc0000005
STACK_TEXT:
ffffec8a`368c73e0 fffff802`6dcd440a : ffffd908`7a266498 ffffd908`78143ad0 ffffd908`7a266050 ffffd908`000000ff : nt!FsRtlAcquireHeaderMutex+0x39
ffffec8a`368c7410 fffff802`6ddaf4fe : ffffec8a`368c77f0 ffffc887`940b6180 ffffd908`7a266050 ffffd908`7a266498 : Ntfs!NtfsTeardownFromLcb+0x16a
ffffec8a`368c74b0 fffff802`6dcd892a : ffffec8a`368c77f0 ffffec8a`368c75b1 ffffd908`7a266498 ffffec8a`368c77f0 : Ntfs!NtfsTeardownStructures+0xee
ffffec8a`368c7530 fffff802`6ddd0cec : ffffec8a`368c7600 ffffd908`00000000 ffffec8a`00000000 ffffec8a`368c77f0 : Ntfs!NtfsDecrementCloseCounts+0xaa
ffffec8a`368c7570 fffff802`6ddcfc31 : ffffec8a`368c77f0 ffffd908`7a2661b0 ffffd908`7a266050 ffffc887`940b6180 : Ntfs!NtfsCommonClose+0x45c
ffffec8a`368c7650 fffff802`6de054d8 : 00000000`0000001c fffff802`6bb8f240 00000000`00000000 00000000`00000000 : Ntfs!NtfsFspCloseInternal+0x241
ffffec8a`368c77b0 fffff802`6b6bd095 : ffffc887`8ec47970 ffffc887`9b18e000 fffff802`6b6f7800 ffffc887`8ec47970 : Ntfs!NtfsFspClose+0x88
ffffec8a`368c7a70 fffff802`6b72a7a5 : ffffc887`9b18e040 00000000`00000080 ffffc887`8ec6c040 000024ef`b59bbfff : nt!ExpWorkerThread+0x105
ffffec8a`368c7b10 fffff802`6b7c8b2a : fffff802`66e87180 ffffc887`9b18e040 fffff802`6b72a750 0006ef80`00000000 : nt!PspSystemThreadStartup+0x55
ffffec8a`368c7b60 00000000`00000000 : ffffec8a`368c8000 ffffec8a`368c1000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x2a
SYMBOL_NAME: nt!FsRtlAcquireHeaderMutex+39
MODULE_NAME:
nt
IMAGE_NAME: ntkrnlmp.exe
IMAGE_VERSION: 10.0.18362.535
STACK_COMMAND: .cxr 0xffffec8a368c69f0 ; kb
BUCKET_ID_FUNC_OFFSET: 39
FAILURE_BUCKET_ID: AV_nt!FsRtlAcquireHeaderMutex
OS_VERSION: 10.0.18362.1
BUILDLAB_STR: 19h1_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {68e5700a-5d25-fc1f-47ba-91e2a2183ad1}
Followup: MachineOwner
BSOD SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e) - Ähnliche Themen
Bluescreens: Hallo erstmal :) Habe Probleme mit regelmäßigen Bluscreens und zwar fing es vor einigen Wochen an. in der Zwichenzeit habe ich bspw nun auch...
Pc stürzt bei spielen ab: Guten Tag, Ich habe ungefähr vor 2 Wochen meinen Pc neu uns sauber aufgesetzt. Allerdings stürzt mein Pc bei Spielen mit mehr Leistung immer...
BSOD KMODE_EXCEPTION_NOT_HANDLED in PpmPerfSelectProcessorState: Hi everyone! I was asked to investigate a KMODE_EXCEPTION_NOT_HANDLED BSOD on a Windows 10 system. Its current (minimal) configuration is...
Nach Crash die Minidump File ausgelesen; was ist das Problem?: Ich hatte vor kurzen einen System Service Exeption Bluescreen, dabei habe ich die Crash File versucht auszulesen, aber selbst komme ich nicht...
BoD (DPC_WATCHDOG_VIOLATION / VIDEO_TDR_FAILURE) due to graphics driver or faulty hardware?: Since quite some time I regularly get BoDs with a DPC_WATCHDOG_VIOLATION (133) and after some driver changes VIDEO_TDR_FAILURE (116)...
casino in washington
shark tank poker
europa casino
europa crasino
, crazy 4 poker, crazy 4 pokSer, casinos in lousianna, casjinos in lousianna, world poker tour schedule, world poHker tour schedule, crown casino, crown casiXno, pkr poker, ca$sino español, party pok%er app, party poker app, casin]o in washington, poker dice, poke/r dice, twin river cQasino, governor of poker 2, governor of Rpoker 2, eldorado casino, eldorado cassino, planet hollywood poker
