GELÖST boot problem
Diskutiere boot problem im WinXP - Allgemeines Forum im Bereich Windows XP Forum; Fehlermeldung: Windows konnte nicht gestartet werden, da folgende Datei fehlt oder beschädigt ist: \Winnt\System32\Config\System.ced :bahnhof...
Metal Head
:bahnhof :redeye :sneaky
Dheller
Here is the article posted at MS Support "Click Here"
Error Message: Windows Could Not Start Because the Following File Is Missing or Corrupt: \Winnt\System32\Config\System.ced (Q269075)
The information in this article applies to:
Microsoft Windows 2000 , Server
Microsoft Windows 2000 , Advanced Server
Microsoft Windows 2000 , Professional
IMPORTANT : This article contains information about editing the registry. Before you edit the registry, make sure you understand how to restore it if a problem occurs. For information about how to do this, view the "Restoring the Registry" Help topic in Regedit.exe or the "Restoring a Registry Key" Help topic in Regedt32.exe.
SYMPTOMS
When you restart your Microsoft Windows 2000-based computer, you may receive the following error message:
Windows could not start because the following file is missing or corrupt:\WINNT\SYSTEM32\CONFIG\SYSTEM.ced
You may also receive the following error message:
System hive error
CAUSE
This behavior can occur if one of the following conditions is true:
A Promise Technology, Inc. ATA66 PCI controller card is installed in the computer. This issue typically occurs during the Windows 2000 installation process.
The System hive in the registry is damaged or missing.
Windows 2000 may be unable to load the registry if it is too large. This issue can occur when a process writes too much data to the System subkey in the registry. The System subkey is designed to contain only the information that is necessary to boot the computer.
Computers that are based on Intel architecture or ARC (RISC) architecture can only use 16 megabytes (MB) of memory at this stage of the boot process. The System registry subkey has to share the 16 MB with the loader, kernel, HAL, and boot drivers. In some instances, the size of the System subkey may be 13 MB or larger.
RESOLUTION
WARNING : Using Registry Editor incorrectly can cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that problems resulting from the incorrect use of Registry Editor can be solved. Use Registry Editor at your own risk.
For information about how to edit the registry, view the "Changing Keys and Values" Help topic in Registry Editor (Regedit.exe) or the "Add and Delete Information in the Registry" and "Edit Registry Data" Help topics in Regedt32.exe. Note that you should back up the registry before you edit it. If you are running Windows NT or Windows 2000, you should also update your Emergency Repair Disk (ERD).
To resolve this issue, use the appropriate method.
Remove the Promise Technology ATA66 PCI Controller
If this issue occurs during the Windows 2000 installation process and a Promise ATA66 controller is installed in your computer, remove the Promise Technology ATA66 PCI controller card, check your BIOS settings to make sure that the IDE controller on your motherboard is enabled, and then run Windows 2000 Setup again.
Restore a Backup of the System Hive
Use the Repair Console tool to replace the backup copy of the System hive from the repair folder. If the Repair Console tool is not installed on your computer, you can run it from the Emergency Repair process:
Use the Windows 2000 CD-ROM or the Windows 2000 Startup disk to start the computer.
When you see the "Welcome to Setup" message, press R for "repair."
Press C to run the Recovery Console tool.
Select the installation that you want to repair.
Type the administrator password.
If the computer is a domain controller, type the password for Directory Services Restore Mode when you are prompted to do so.
For additional information about the Recovery Console tool, click the article numbers below to view the articles in the Microsoft Knowledge Base:
Q239803 How to Change the Recovery Console Administrator Password on a Domain Controller
Q223301 Protection of the Administrator Account in the Offline SAM
At the Recovery Console command prompt, type the following commands, pressing ENTER after you type each command:
cd system32\config
ren system system.old
ren system.alt systemalt.old
If you have run the Emergency Repair Disk Wizard from Windows Backup and Recovery tools, copy the backup of the System hive from the %SystemRoot%\Repair\Regback folder.
If you have not run the Emergency Repair Disk Wizard, copy the default System hive from the %SystemRoot%\Repair folder.
IMPORTANT : You need to restore the most recent copy of the System hive. You also need to reinstall any hardware device drivers or programs that run as services that you installed since the last time that you updated your Emergency Repair Disk.
To copy the default System hive, type the following command, and then press ENTER:
copy c:\winnt\repair\system to copy the default system hive
To copy the System hive that was backed up the last time that you ran the Emergency Repair Disk Wizard, type the following command, and then press ENTER:
copy c:\winnt\repair\regback\system
At the command prompt, type exit , and then press ENTER to restart your computer.
Reduce the Size of the System Hive
If a large number of resources are shared on the computer, the registry may become too large. To resolve this issue, use the following steps.
Start registry editor (Regedt32.exe).
Locate and click the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\LanmanServer\Shares
On the Registry menu, click Save Key .
In the File name box, type Shares.new , and then click Save .
HKEY_LOCAL_MACHINE
On the Registry menu, click Load Hive .
In the list of files, click the System.old file, and then click Open .
In the Key Name box, type System.old , and then click OK .
HKEY_LOCAL_MACHINE\SYSTEM\Select
Note the setting for the Default value.
HKEY_LOCAL_MACHINE\System.old\ControlSet x \Services\LanmanServer\Shares
where x is the number that you noted in step 8.
In the File name box, type Shares.old , and then click Save .
Restore the Shares.new key to the System.old registry hive:
HKEY_LOCAL_MACHINE\System.old\ControlSetx\Services\LanmanServer\Shares
Click the HKEY_LOCAL_MACHINE\System.old key.
On the Registry menu, click Unload Hive .
Quit Registry Editor.
Restart the computer to the Recovery Console.
At the command prompt, type the following lines, pressing ENTER after you type each line:
ren system system.org
ren system.old system
At the command prompt, type exit , and then press ENTER to restart the computer.
MORE INFORMATION
For additional information about how to obtain Windows XP Setup boot disks, click the article number below to view the article in the Microsoft Knowledge Base:
Q310994 Obtaining Windows XP Setup Boot Disks
The third-party products discussed in this article are manufactured by vendors independent of Microsoft; we make no warranty, implied or otherwise, regarding these products' performance or reliability.
Viel Erfolg. :sing
Ich ha zwar nciht gelesen was drin steht, wird aber bestimmt klappen ;)
Dheller
Hier isse snochmal was kürzer. Gilt auch für XP!!!
Well its not missing and its probably not corrupt. You get this message if something is writing too much data to the System subkey in the registry. Think about what you have installed lately.
Intel and ARC (RISC) systems have a design limit such that 16 megabyte (MB) of memory is available at this stage of the boot process and the following must fit in that available 16M RAM :
loader
kernel
HAL
boot drivers
system registry hive
If the System registry hive exceeds 13MB, you get that error. To resolve the problem, you have to replace it with a backup version. Use the Repair Console tool to replace the backup copy of the System hive from the repair folder. If you do not have the Repair Console tool installed, you can run it from the Emergency Repair process:
Start the computer by using the Windows CD-ROM or the Startup disk.
Type the administrator password. If this is a domain controller, you need to supply the password for Directory Services Restore Mode.
Log on to the Recovery Console tool and type the following commands:
cd system32\config
Copy the backup of the System hive from either the %SystemRoot%\Repair folder or the %SystemRoot%\Repair\Regback folder if you run the Emergency Repair Disk Wizard from Windows Backup and Recovery tools.
You will need to restore the most recent copy of the System hive. Any programs that run as a service or hardware device drivers that you installed since you last ran the Emergency Repair Disk need to be re-installed.
To copy the default System hive, type the following command:
To copy the System hive that was backed up the last time that you ran the Emergency Repair Disk Wizard, type the following command:
After you run these commands, type exit at the command prompt to restart your computer.
Viel Erfolg!
:sing
boot problem
boot problem - Ähnliche Themen
Datei "stdole32.tlb" lässt sich nicht ersetzen: Hallo, bei mir hat sich folgendes Problem eingestellt: Wenn ich mit meinem Office 2003 eine Excel-Datei neueren Datums öffnen möchte...
Fehlermeldung! Kein öffnen von Premiere Pro, Ae, oder Power DVD mehr möglich!: Hallo Zusammen, leider stoße ich gerade bei einem Problem an meine Grenzen. Ich wollte letztens wie gewohnt mein Premiere Pro öffnen und ein...
Windows XP starten nicht: Hallo, Seit einiger Zeit startet das o.g. Betriebssystem nicht mehr. Ich habe daraufhin Testdisk angewandt, welches sich auf einer Notfall-CD...
Fehlende Dateien bei Installation: Hallo Ich habe folgendes Problem, wenn ich Windows 10 neu installiere auf ein komplett leeren SSD kommt bei ca. 75% die Fehlermeldung das Daten...
Windows erkennt Tastatur nicht mehr: Hallo, ich habe seit Tagen ein Problem mit meinem Pc. Das erste Problem wurde mir angeziegt als ich den pc neu gestartet habe. Windows zwigt an...
