Bildlaufleiste in JavaScript
Diskutiere Bildlaufleiste in JavaScript im Internet Forum Forum im Bereich Software Forum; Guten Tag! Ich möchte gerne eine senkrechte Bildlaufleiste erstellenm, die waagrechte hab ich zusammengebracht! Also hier mal der Code, was muss...
A_geh
Guten Tag!
Also hier mal der Code, was muss ich ändern für eine waagrechte?
Code:
var sliderwidth = 550;
var sliderheight = 80;
var slidespeed = 1;
var slidebgcolor = "#FFFFFF";
var leftrightslide = new Array();
var copyspeed = slidespeed;
var i = 0;
leftrightslide[i++] = '<a href="0001.html"><img src="_files/images/thumbs/0001.jpg"></a>';
leftrightslide[i++] = '<a href="0004.html"><img src="_files/images/thumbs/0004.jpg"></a>';
leftrightslide[i++] = '<a href="0005.html"><img src="_files/images/thumbs/0005.jpg"></a>';
leftrightslide[i++] = '<a href="0006.html"><img src="_files/images/thumbs/0006.jpg"></a>';
leftrightslide[i++] = '<a href="0010.html"><img src="_files/images/thumbs/0010.jpg"></a>';
leftrightslide[i++] = '<a href="0011.html"><img src="_files/images/thumbs/0011.jpg"></a>';
leftrightslide[i++] = '<a href="0012.html"><img src="_files/images/thumbs/0012.jpg"></a>';
leftrightslide[i++] = '<a href="0013.html"><img src="_files/images/thumbs/0013.jpg"></a>';
leftrightslide[i++] = '<a href="0014.html"><img src="_files/images/thumbs/0014.jpg"></a>';
leftrightslide[i++] = '<a href="0015.html"><img src="_files/images/thumbs/0015.jpg"></a>';
leftrightslide[i++] = '<a href="0016.html"><img src="_files/images/thumbs/0016.jpg"></a>';
leftrightslide[i++] = '<a href="0023.html"><img src="_files/images/thumbs/0023.jpg"></a>';
leftrightslide[i++] = '<a href="0024.html"><img src="_files/images/thumbs/0024.jpg"></a>';
leftrightslide[i++] = '<a href="0026.html"><img src="_files/images/thumbs/0026.jpg"></a>';
leftrightslide[i++] = '<a href="0027.html"><img src="_files/images/thumbs/0027.jpg"></a>';
leftrightslide[i++] = '<a href="0030.html"><img src="_files/images/thumbs/0030.jpg"></a>';
leftrightslide[i++] = '<a href="0031.html"><img src="_files/images/thumbs/0031.jpg"></a>';
leftrightslide[i++] = '<a href="0033.html"><img src="_files/images/thumbs/0033.jpg"></a>';
leftrightslide = '<nobr>' + leftrightslide.join(" ") + '</nobr>';
var iedom = document.all || document.getElementById;
if (iedom)
	document.write('<span id="temp" style="visibility:hidden;position:absolute;top:-100;left:-3000">' + leftrightslide + '</span>');
var actualwidth = '';
var cross_slide, ns_slide;
function fillup(){
	if (iedom){
		cross_slide=document.getElementById? document.getElementById("test2") : document.all.test2;
		cross_slide2=document.getElementById? document.getElementById("test3") : document.all.test3;
		cross_slide.innerHTML=cross_slide2.innerHTML=leftrightslide;
		actualwidth=document.all? cross_slide.offsetWidth : document.getElementById("temp").offsetWidth;
		cross_slide2.style.left=actualwidth+20;
	else if (document.layers){
		ns_slide=document.ns_slidemenu.document.ns_slidemenu2;
		ns_slide2=document.ns_slidemenu.document.ns_slidemenu3;
		ns_slide.document.write(leftrightslide);
		ns_slide.document.close();
		actualwidth=ns_slide.document.width;
		ns_slide2.left=actualwidth+20;
		ns_slide2.document.write(leftrightslide);
		ns_slide2.document.close();
	lefttime=setInterval("slideleft()",30);
window.onload=fillup;
function slideleft(){
	if (iedom){
		if (parseInt(cross_slide.style.left)>(actualwidth*(-1)+8))
			cross_slide.style.left=parseInt(cross_slide.style.left)-copyspeed;
		else
			cross_slide.style.left=parseInt(cross_slide2.style.left)+actualwidth+30;
		if (parseInt(cross_slide2.style.left)>(actualwidth*(-1)+8))
			cross_slide2.style.left=parseInt(cross_slide2.style.left)-copyspeed;
		else
			cross_slide2.style.left=parseInt(cross_slide.style.left)+actualwidth+30;
		if (ns_slide.left>(actualwidth*(-1)+8))
			ns_slide.left-=copyspeed;
		else
			ns_slide.left=ns_slide2.left+actualwidth+30;
		if (ns_slide2.left>(actualwidth*(-1)+8))
			ns_slide2.left-=copyspeed;
		else
			ns_slide2.left=ns_slide.left+actualwidth+30;
if (iedom||document.layers){
	with (document){
		document.write('<table border="0" cellspacing="0" cellpadding="0"><td>');
		if (iedom){
			document.write('<div style="position:relative;width:' + sliderwidth + ';height:' + sliderheight + ';overflow:hidden">');
			document.write('<div style="position:absolute;width:' + sliderwidth + ';height:' + sliderheight + ';background-color:' + slidebgcolor + '" onMouseover="copyspeed=0" onMouseout="copyspeed=slidespeed">');
			document.write('<div id="test2" style="position:absolute;left:0;top:0"></div>');
			document.write('<div id="test3" style="position:absolute;left:-1000;top:0"></div>');
			document.write('</div></div>');
			document.write('<ilayer width='+sliderwidth+' height='+sliderheight+' name="ns_slidemenu" bgColor='+slidebgcolor+'>');
			document.write('<layer name="ns_slidemenu2" left=0 top=0 onMouseover="copyspeed=0" onMouseout="copyspeed=slidespeed"></layer>');
			document.write('<layer name="ns_slidemenu3" left=0 top=0 onMouseover="copyspeed=0" onMouseout="copyspeed=slidespeed"></layer>');
			document.write('</ilayer>');
		document.write('</td></table>');
</script>
javascript ns_slide
bildlaufleiste funkion
Bildlaufleiste in JavaScript - Ähnliche Themen
  • Im Outlook 2013 ist im Eingangsordner die vertikale Bildlaufleiste verschwunden.
    Im Outlook 2013 ist im Eingangsordner die vertikale Bildlaufleiste verschwunden.: Bei den anderen Ordner ist die Leiste noch da. Ich finde nicht heraus wie ich die Bildlaufleiste wieder holen kann. Die Lösung über...
  • Scrollen mit der Bildlaufleiste bei Breitbild-PC
    Scrollen mit der Bildlaufleiste bei Breitbild-PC: Bei meinem Breitbild-Laptop scrollt die Seite im Fenster beim Antippen mit dem Touchpad ober- oder unterhalb des Führungsbalkens immer um ein paar...
  • Bildlaufleiste scrollt ganz ans Ende
    Bildlaufleiste scrollt ganz ans Ende: Beim einfügen einer Datei in ein Verzechnis (rechte Maus-Taste + Kontext"kopieren" danch rechte Maus-Taste und Kontext"einfügen" oder mit STRG +...
  • Excel: Bildlaufleiste horizontal
    Excel: Bildlaufleiste horizontal: Hallo, kann mir jemand sagen, wie ich Einstellungen für die horizontale Bildlaufleiste vornehmen kann? Ich war gewohnt, dass wenn ich den...
  • Cursor und vertikale Bildlaufleiste funktionieren nicht
    Cursor und vertikale Bildlaufleiste funktionieren nicht: Hallo zusammen, ich habe MS Office 2007. MS Word habe ich einen Monat nicht benutzt und bekomme jetzt plötzlich folgende Fehler: Beim direkten...
