Probiere es doch mal so
1. BGInfo starten
2. Button "Custom"
3. Button "New..."
4. WMI-Query anklicken
5. "Browse" anklicken
6. select currentclockspeed from win32_processor in das Feld eingeben, dann auf "Evaluate" klicken
7. Alles übernehmen (OK oder Apply)
Hier sind weitere Daten, die du abfragen kannst. Die Bezeichnung steht immer als erstes. Das siehst du z.B. bei currentclockspeed:
Device Remover [Beta 4] on DELL
User Context: dell\Peter
Date/Time captured: 19.08.2009 19:36:49
WMI/WQL Result for Query: "select * from win32_processor" on DELL
Name,"CIM Type","Value"
AddressWidth,"UInt16","64"
Architecture,"UInt16","9"
Availability,"UInt16","3"
Caption,"String","Intel64 Family 6 Model 22 Stepping 1"
ConfigManagerErrorCode,"UInt32","No Information available"
ConfigManagerUserConfig,"Boolean","No Information available"
CpuStatus,"UInt16","1"
CreationClassName,"String","Win32_Processor"
CurrentClockSpeed,"UInt32","1862"
CurrentVoltage,"UInt16","33"
DataWidth,"UInt16","64"
Description,"String","Intel64 Family 6 Model 22 Stepping 1"
DeviceID,"String","CPU0"
ErrorCleared,"Boolean","No Information available"
ErrorDescription,"String","No Information available"
ExtClock,"UInt32","133"
Family,"UInt16","15"
InstallDate,"DateTime","No Information available"
L2CacheSize,"UInt32","1024"
L2CacheSpeed,"UInt32","No Information available"
L3CacheSize,"UInt32","0"
L3CacheSpeed,"UInt32","0"
LastErrorCode,"UInt32","No Information available"
Level,"UInt16","6"
LoadPercentage,"UInt16","1"
Manufacturer,"String","GenuineIntel"
MaxClockSpeed,"UInt32","1862"
Name,"String","Intel(R) Celeron(R) CPU 540 @ 1.86GHz"
NumberOfCores,"UInt32","1"
NumberOfLogicalProcessors,"UInt32","1"
OtherFamilyDescription,"String","No Information available"
PNPDeviceID,"String","No Information available"
PowerManagementCapabilities,"UInt16","No Information available"
PowerManagementSupported,"Boolean","False"
ProcessorId,"String","AFEBFBFF00010661"
ProcessorType,"UInt16","3"
Revision,"UInt16","5633"
Role,"String","CPU"
SocketDesignation,"String","Microprocessor"
Status,"String","OK"
StatusInfo,"UInt16","3"
Stepping,"String","No Information available"
SystemCreationClassName,"String","Win32_ComputerSystem"
SystemName,"String","DELL"
UniqueId,"String","No Information available"
UpgradeMethod,"UInt16","6"
Version,"String","Empty String"
VoltageCaps,"UInt32","2"
