Battery charging -> watching a video -> the laptop becomes warm/ hot, CPU fan runs at high speed!
Diskutiere Battery charging -> watching a video -> the laptop becomes warm/ hot, CPU fan runs at high speed! im Surface Book / Pro Forum im Bereich Microsoft Community; Battery charging -> watching a video -> the laptop becomes warm/ hot, CPU fan runs at high speed! Hi, I have the following problem and I am...
I have the following problem and I am pretty sure that is typical Surface Book 2 problem, everybody can reproduce it:
Surface Book 2, 15 inch, RAM: 16 GB, SSD: 512 GB
I have just reset my Surface and I have all of the updates.
Test1:
0. Power mode: Best performance, Wifi On
1. plug the charging connector into the charging port on your Surface
2. charge the battery to 100%
3. DO NOT UNplug the charger
4. close all of your running applications
5. restart your laptop
6. start the Edge browser
7. navigate to youtube.com and start an HD or a higher quality video
8. wait some minutes and your Surface becomes warm/ hot, CPU fan runs at high speed!
9. set the power mode to battery saver and wait some minutes, everything is OK again
10. set the power mode to best performance again and wait some minutes, your Surface becomes warm/ hot, CPU fan runs at high speed!
Test2:
1. DO NOT plug the charging connector into the charging port on your Surface
2. use your Surface and wait until the battery is below 98%
3. DO NOT plug the charger
8. wait some minutes and everything is OK again
9. plug the charging connector into the charging port on your Surface
10. charge the battery to 100%
11. your Surface becomes warm/ hot, CPU fan runs at high speed!
Test3:
8. put your Surface (the tablet part) close to your ears, you can hear a very silent noise!
10. put your Surface (the tablet part) close to your ears again , you cannot hear this noise anymore!
Any idea? What could be the problem?
Battery charging -> watching a video -> the laptop becomes warm/ hot, CPU fan runs at high speed! - Ähnliche Themen
  • after battery change battery is not charging anymore
    after battery change battery is not charging anymore: Windows 10 latest update installiert. Ultrabook Toshiba Satellite Z930-130 (4-5 years old) new OEM battery replaced the old one. but it is not...
  • after battery change battery is not charging anymore.
    after battery change battery is not charging anymore.: Windows 10 latest update installiert. Ultrabook Toshiba Satellite Z930-130 (4-5 years old) new OEM battery replaced the old one. but it is not...
  • Surface Pro battery drains within 30 minutes
    Surface Pro battery drains within 30 minutes: Dear community, I have a Surface Pro and since an update in September 2019 battery drains pretty quickly (4 hours, before it was 10 hours). But...
  • Surface Pro 4 swollen battery and bent screen
    Surface Pro 4 swollen battery and bent screen: Hello there My Surface Pro 4 has a swollen battery and a bent screen. It is unfortunate because this is a replacement model of a previous one...
