Andauernde Abstürze
Diskutiere Andauernde Abstürze im Windows 10 Forum im Bereich Microsoft Community; Hallo zusammen, vor knapp 2 Wochen meine CPU und mein Mainboard gewechselt. Ich habe seitdem alle Treiber und das BIOS aktualisiert. Trotzdem...
  • Andauernde Abstürze Beitrag #1
vor knapp 2 Wochen meine CPU und mein Mainboard gewechselt. Ich habe seitdem alle Treiber und das BIOS aktualisiert. Trotzdem kommt es andauernd zu Abstürzen. Folgendes bekomme ich bei "WhoCrashed" angezeigt:
On Mon 20.01.2020 15:38:54 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\012020-9265-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1C14E0)
Bugcheck code: 0x7F (0x8, 0xFFFFA6011A5CB0B0, 0xFFFFDF856C208960, 0xFFFFF80378EA82F3)
Error: UNEXPECTED_KERNEL_MODE_TRAP
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the Intel CPU generated a trap and the kernel failed to catch this trap.Double Fault, indicates that an exception occurs during a call to the handler for a prior exception. Most often this is caused by a software problem (kernel stack overflow) but this can also be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!setjmpex+0x8149)
On Sun 19.01.2020 17:07:40 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\011920-8234-01.dmp
Bugcheck code: 0x50 (0xFFFF8A8254CCF000, 0x11, 0xFFFF8A8254CCF000, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
On Thu 16.01.2020 19:48:23 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\011620-8125-01.dmp
This was probably caused by the following module: hal.dll (hal+0x499F1)
Bugcheck code: 0x9C (0x0, 0xFFFFF8055F824B30, 0x0, 0x0)
Error: MACHINE_CHECK_EXCEPTION
file path: C:\WINDOWS\system32\hal.dll
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal machine check exception has occurred.
____
Meine System Specs:
Windows 10 Pro
Mainbaord: MSI MPG Z390 Gaming Edge AC
CPU : I7 9700K
Grafikkarte: RTX 2070Super
___
DMP Files:
Download dmp FIles.rar (304.03 KB) now. Fast and easy at workupload.com
_
Habt ihr eine Idee wie man das Problem lösen kann?
Vielen Dank schon mal im voraus.
Andauernde Abstürze
Andauernde Abstürze - Ähnliche Themen
Bluescreens: Hallo liebe MS-Community, ich habe in letzter Zeit öfters Bluescreens. Habe den PC seit ca. 3-4 Wochen zusammengebaut. Als ich mir das mit...
ntkrnlmp.exe (nt!KeWriteProtectPAT+0x123A) Blue Screen: This was probably caused by the following module: ntkrnlmp.exe (nt!KeWriteProtectPAT+0x123A) Bugcheck code: 0xC000021A (0xFFFFD40989F4E3D0...
CRITICAL_PROCESS_DIED- BSoD wegen ntdll.sys und ntoskrnl.exe: Ich habe seit kurzem immer das Problem, dass wenn ich während ich Spiele , die Audio rumspackt, ich danach ein Standbild kriege auf welches ein...
BSOD "SYSTEM_SERVICE_EXCEPTION (win32kbase.sys)": Hallo folgendes Problem, am Freitag ist mein PC von der Reparatur wiedergekommen(laut Reperaturbericht war die CPU sowie speicher hinüber), habe...
BSOD seit einigen Wochen: Hallo zusammen, seit einigen Wochen habe ich Probleme mit BSOD an meinem Rechner. Es hat angefangen indem der BSOD währen der Nutzung ab und zu...
hollywood casino joliet
orleans casino
is online poker illegal
is online Opoker illegal
, mohegan sun casino, mohegan sun caspino, poker tables for sale, pokegr tables for sale, who is the best poker player in the world, casino in west virginia, tilt poker, lco casino, how do you play 3 card poker, cherokee cawsinos, cherokee casinos, world p0oker club, detroit casinos, detroit casi[nos, european poke0r tour, casino themed party, cas0ino themed party, zynga poker online, zynga p3oker online, doubleu caRsino free chips, play poker for fun
